    Buy Download Package Now!
Motion Sickness with VR+Moving platform
Discussion in 'VR Headsets and Sim Gaming - Virtual Reality' started by Brass Yeti, Feb 7, 2019.
  1. Brass Yeti
    Brass Yeti All show - No go
    United States
    156Coins
    I just received my DOF Reality P3 and got it working with Project Cars. I have had a static cockpit for years and loved playing PCars2 in VR with it, however I am getting a lot of motion sickness once I experienced the 3dof movement from my new cockpit. I cant even finish a lap at Road America.
    Has anyone experienced a similar transition? Does motion cancelling help? I am currently just running it off of an external sensor.
  2. SeatTime
    SeatTime Well-Known Member SimTools 2.0 Beta Tester
    Newcastle Australia
    26,133Coins
    From my and others experience, a 'good' motion system will reduce the incidence of VR sickness. But a 'bad' motion system can actually make it worse. A 'good' motion system will move your head (inner ear) fast and accurately to track/mimic what is being seen through the VR headset - yes motion cancellation can help. A 'Bad' motion system will not do this - even a incorrect roll center can effect some people. Not Everyone has the same threshold, but you can train yourself to increase this threshold.
  3. SeatTime
    Newcastle Australia
    26,133Coins
    I would try reducing the amount of movement, especially were pitch and roll is being use to simulate surge and Sway and see if this helps. As your body then becomes more conditioned, you can slowly increase it back up. Baby steps - short stints, or your body will relate your rig/VR headset to poison.
  4. Gadget999
    Gadget999 Active Member
    4,722Coins
    something that works in my experience is being able to see the horizon - if you feel sick on a boat make sure you can see the horizon and the effects go away
    does your game have a view where you can see the horizon ?
  5. Brass Yeti
    United States
    156Coins
    I removed sway and surge and I think it helped. Good idea. Makes sense since its a 3dof machine trying to simulate a 6 dof machine
  6. Thanos
    Thanos Active Member
    United States
    1,959Coins
    2DOF, 3DOF, DC motor, AC motor, Joyrider, Motion platform, 6DOF
    Suggestion for car racing , short and synchronized motion cues are the only way to avoid motion sickness with VR.
    And as low latency is possible!
    Thanos
  7. misoswan
    misoswan Active Member
    770Coins
    3DOF, Arduino, JRK
    hello where buy this linear actuator?
    thanks
  8. Javo5
    Javo5 Active Member
    Buenos Aires, Argentina
    234Coins
    I have a DIY 2DOF, with quick and short movements. Less motion sickness than the static cockpit
