Question Motion Cancellation Oculus Rift CV1 - or new headset?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by zylle, Feb 6, 2021.
  1. zylle
    zylle New Member
    Denmark
    124Coins
    Hey guys!
    A bit long since i've posted here, but I am currently in the midst of planning a new motion sim build with VR.
    I remember when i left my old sim that there where problems with mounting the oculus sensor directly on the rig - and that motion cancellation was preffered for this.
    My question is: is there any solutions with motion cancellation for the Oculus CV1 as it stands now - or are there better headsets currently which is suggested?
    Thanks a lot in advance - and i will deffo share my progress when i get longer than the napkin drawings i have atm ;)
    • Optimistic Optimistic x 1
    153,001Coins
    +11,116 / 56 / -2
  3. Sim Freak
    Sim Freak Sim Freak Gold Contributor
    61Coins
    Actually my experience it the opposite!
    Even though the CV1 visual quality is pretty out of date now, I've kept using it purely because the sensors can be mounted directly onto the rig for motion compensation. I had no problem mounting the sensor (just 1 is enough) to my aluminum profile rig. It worked really well with my full 3DOF+TL+Surge and 4 transducers. The screw thread on the sensor is not the standard pitch (1mm I think). You just need to get the screw and you can pretty much mount it on anything.
    Recently I bit the bullet and switched to PIMAX 8KX, with 2 lighthouses mounted on the wall and a controller on the rig. But it was impossible to get PiTools MC or OVRMC to work due to the excessive vibration. It's a very challenging to mount the controller sturdily due to it's shape. I will have to look at other mounting option, but for now, I really have to tune down motion otherwise there's just too much offset between my body and the visual in VR.
  4. Redjack
    Redjack New Member
    17Coins
    4DOF
    Hello Sim Freak. can u send me a picture of u did attach the CV1 sensor to the alluminium rig. and how and which screws did u use.ty a lot. Im building my motion system.ty
