Motion canceling with rumble packs
Discussion in 'VR Headsets and Sim Gaming - Virtual Reality' started by Anthony Morris, Apr 7, 2019.
  1. Anthony Morris
    Anthony Morris Member Gold Contributor
    Multi trade
    Essex UK
    37Coins
    I've been looking at this for myself so I tried this yesterday it works to cancel the noise 100% I turned the shakers up to full with no interference at all BUT after more testing could not get rid of after wobble from the chair moving I tightened up the elastic to the point the noise was worse than I started with
    So I ended back here with acoustic foam and elastic it removes near all the noise has no after wobble at all I may improve on this with an acoustic foam sleeve
    With a graphic as well I have this working pretty much perfick
    I may give the new sib vibe another go now weeeeeeee
  2. Anthony Morris
    Multi trade
    Essex UK
    37Coins
    I have removed all of the noise from rumble packs at full volume with a £2 gel pack between the controller and chair AWESOME
  3. SilentChill
    20,668Coins
    Where did you get the Gel pack ?
  4. Anthony Morris
    Multi trade
    Essex UK
    37Coins
    this was a hot/cool gel pack from Amazon 2 for £4 free delivery not too shabby and it has removed all the noise I have the full 550 watt rms bumping through the frame and seat is just AWSOME
  5. Anthony Morris
    Multi trade
    Essex UK
    37Coins
  6. 4apaev
    4apaev Member
    Media
    Moscow, Russia
    486Coins
    I made smthg similar, no luck. It either catch vibrations when bolted too tight, or gets wobbly on the chair movement when loose. Only thing that worked somehow is pressing it with hand. Human body seems to be the best thing for absorbing vibrations :)
    • Dislike Dislike x 1
  7. SilentChill
    20,668Coins
    Do you have a link ?
  8. Anthony Morris
    Multi trade
    Essex UK
    37Coins
    Would you like me to ordet it 4 u I can do this tomorrow.
    Dude I promise you this is 99% on physical movement and 100% on noise
  9. SilentChill
    20,668Coins
    No you dont need to order I can order it just wanted to see which you ordered
  10. Anthony Morris
    Multi trade
    Essex UK
    37Coins
    HypaGel Reusable Hot & Cold Pack - Standard (Pack of 2)
    I have folded over an end to keep it pumped up and with the sleeve on do the elastic up super tight. The gel pack is heavy smaller would be better or glue something on the chair for the gel pack to hold on too mines a small strip of foam
  11. Anthony Morris
    Multi trade
    Essex UK
    37Coins
    Its not pasted across soz. I'll try on desk top later
    HypaGel Reusable Hot & Cold Pack - amazon.co.uk/dp/B07DFFB6BS
  12. SilentChill
    20,668Coins
    Cheers matey, I've ordered some give it a go
  13. Anthony Morris
    Multi trade
    Essex UK
    37Coins
    Have u got these yet hows the testing going
  14. 4apaev
    4apaev Member
    Media
    Moscow, Russia
    486Coins
    Here is my version of gel pack support. 2 sacks of gel sandwitched between 2 mounting plates (or whatever they called in English). Of course, no metal parts are in direct contact with vibrating chair support.
    No motion after-wobble with tightly fastened bolts whatsoever.
    It does effectively eliminate jitter from engine noise (I play Elite and Il-2 for the most part), makes fast recovery and doesn’t allow for lasting effects from cannon fire. However, low rumble, coming from weapons fire and explosions still affect it, albeit far from non-playable level they do with plain rigid suppot. Not perfect solution by far, but passable for now.
    Still thinking on how to improve it.
  15. Anthony Morris
    Multi trade
    Essex UK
    37Coins
    I have a full 550 watts pumping me out of my chair now and with the elastic done as tight as it goes I get no physical movement at all. Can I suggest you replace the nuts and bolts with 4mm elastic wound through the holes
  16. Anthony Morris
    Multi trade
    Essex UK
    37Coins
    use a slip knot so you can tighten this right up
  17. Anthony Morris
    Multi trade
    Essex UK
    37Coins
    and lose one of the gel packs
  18. SilentChill
    20,668Coins
    Pictures tell a thousand words :)
  19. Anthony Morris
    Multi trade
    Essex UK
    37Coins
    Latest hardware update 20190702_124232.jpg 20190702_145343.jpg 20190702_145423.jpg 20190702_145458.jpg 20190702_145523.jpg
  20. Anthony Morris
    Multi trade
    Essex UK
    37Coins
    This set up is still working 100% untouched months later.
    When I started out with this it was 2 weeks away from the 'hopefully' update and github was alive with worried peeps
