Tutorial MDBOX audio vibration - step by step guide
Discussion in 'DIY Motion Simulator Projects' started by Megasim, Apr 7, 2020.
  1. Megasim
    Megasim New Member
    27Coins
    2DOF, 3DOF
    Hi guys this is a free tutorial offered by Megasim to anyone needs info on this topic.
    Introduction
    One of the main goal for a simracer is to reach the maximum level of immersion possible. This goal can be chased adding some real life effect on your rig, like force feedback on the wheel and dynamic movements of the platform.
    Vibrations can play an important role in the whole experience of a racing driver, the secret is having an high performance system to produce the effects with the right setting. Usually bass shackers or butt kickers are used for this application, but we have a better alternative and that’s the MS103 actuators kit.
    That’s right, those powerful actuators not only have amazing performance as a dynamic platform, but they can integrate vibrations effects with just a special cable and one usb audio card, paired with SimTools.
    What is it?
    This is a quick guide to enable vibration feedback on the MS103 actuators kit. Follow closely all the steps to reach the intended goal.
    What do you need?
    You need a MDBOX-NV30xXEV4 controller unit, one custom audio cable and another audio card.
    About the controller
    In order to meet the 4D cinema audio vibration special effects function, the company recently launched a new controller with audio vibration MDBOX-NV3030EV4, added AD interface based on MDBOX-NV3030EV2, directly connected to audio analog signal, with 2 convenient interface Multiple units are connected in parallel, and the controller internally controls the servo motor to vibrate with the frequency and amplitude of the audio signal. The motor drives the transmission structure such as the electric cylinder to vibrate like a subwoofer, which brings double impact of hearing and feeling. This scheme is more integrated and cost-effective than the 4D cinema traditional solution to increase the audio decoder and audio filter. The gain, zero drift and filter parameter adjustment are more convenient. Continues...
    Read the full guide on Megasim website, click here!
  2. Ads Master
    Ads Master
