Mario's Tronic Joy Based Sim
Discussion in 'DIY Motion Simulator Projects' started by Guppie5220, Mar 10, 2010.
  1. Guppie5220
    Guppie5220 New Member
    Mechanical Engineer
    Miami FL US
    405Coins
    I would like to share the building of my simulator. Many thanks to Thanos!...Here goes....
  2. Frakk
    Frakk Active Member
    328Coins
    Your seat looks promising! Keep it up! :D
  3. Guppie5220
    Mechanical Engineer
    Miami FL US
    405Coins
    Thank you. Here is what I did today
  4. Guppie5220
    Mechanical Engineer
    Miami FL US
    405Coins
    And this...Slowly but surely
  5. Guppie5220
    Mechanical Engineer
    Miami FL US
    405Coins
    And cockpit is done and waiting for PCBexpress... :D
    For those working with Schedule 40 pvc, I used 1/4 thicker than recommended for the cockpit to minimize flex.
    Next step...Gimbal and castors :clap:
  6. Frakk
    Frakk Active Member
    328Coins
    You are progressing very fast! I really like the white tubing. Are you getting the AMC with the DSMhb?
  7. Guppie5220
    Mechanical Engineer
    Miami FL US
    405Coins
    Hi Frakk. The tubing here in USA is in white. The gray tube is electrical PVC and expensive.
    Yes I am doing AMC and DSMhb. I have all of the components on hand already. Just waiting on PCB boards. Its been over 2 weeks. And from what I have read here it takes 2 weeks or less. I just sent Heinz an email. Lets see what happens.
  8. ralphvdberg
    ralphvdberg New Member
    Racecar/Porsche mechanic
    Netherlands
    277Coins
    Nice the white tubes... looks great!! Keep it up...
  9. Guppie5220
    Mechanical Engineer
    Miami FL US
    405Coins
    Hello everybody..
    Can somebody translate this for me? I do not speak German.
    Sorry ich melde mich morgen bei dir.
    Thank you
  10. egoexpress
  11. Guppie5220
    Mechanical Engineer
    Miami FL US
    405Coins
    Thank you so much Egoexpress. Google works better. I tried using another translator and it didnt make sense.
    Thank you
  12. Guppie5220
    Mechanical Engineer
    Miami FL US
    405Coins
    got the boards
  13. Guppie5220
    Mechanical Engineer
    Miami FL US
    405Coins
    slept all day
  14. Frakk
    Frakk Active Member
    328Coins
    Looking good! Don't worry about the electronics, you can get everything else done before. Do you have the motors already?
  15. Guppie5220
    Mechanical Engineer
    Miami FL US
    405Coins
    Thank you Frakk!
    I dont have the motors yet
  16. Guppie5220
    Mechanical Engineer
    Miami FL US
    405Coins
    Hello to all. I finally got the email I wanted to hear. The boards will be shipped next week. :D
  17. Frakk
    Frakk Active Member
    328Coins
    Awesome! When you look for a wiper motor, try to look for those that run at same torque and speed for both directions.
    You are better off with belts and pulleys. With a servo arm you don't have leverage because the movement of the shaft will be 180deg maximum. You will need extra gearing to achieve sufficient torque that way. With a pulley you can gear the movement very precisely with the least number of components and find a balance between speed and torque. Don't forget, first you need torque to start moving something fast.
  18. Guppie5220
    Mechanical Engineer
    Miami FL US
    405Coins
    Ahh yes. I see what you mean Frakk. With a servo arm it wont be linear at all like a pulley system even if the mechanical advantage could be achieved.
  19. Frakk
    Frakk Active Member
    328Coins
    Servo arms have no advantage. As I posted, the arm only moves 180 degrees maximum which has to be translated to the cockpit movement. With the pulley setup, you can gear it to the best torque/speed ratio. These motors run at a fairly fast RPM (compared to a servo arm movement), so you will want at least 6-10 motor turns to move the cockpit through the range.
    I can't recommend any motors because I haven't purchased any. I don't know if those motors are the same or not, but I suggest they are very similar in performance.
  20. Guppie5220
    Mechanical Engineer
    Miami FL US
    405Coins
    Im still confused a bit.
