Low cost 2DOF/3DOF/4DOF/6DOF motion simulator - DOF REALITY
Discussion in 'Commercial Simulators and Peripherie' started by Radioproffi, May 23, 2016.
  1. Spittfire88
    Spittfire88 New Member
    USA
    143Coins
    Hey spit,
    I fly dcs and bms quite a bit. I had the cv1 but sold it since i wasnt a big fan of the sacrifice in resolution, etc. Would you recommend this rig for avid flight simming with trackir?
  2. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,946Coins
    I think probably not, for 3 reasons.
    1. I presume you'd want your screen(s) mounted to the rig, and i'm fairly sure they say it isn't designed for that weight on the front
    2. I think without VR you'd want a 6dof for realistic feel (generally the view is that flightsim needs 6dof, but i'm hopeful that this kind of platform works in the more immersive world of VR, when properly tuned)
    3. Right now i think there are some issues with the tuning filters in simtools which are preventing me getting acceptable movement profiles.
    Personally i'm shifting focus to building a g-seat until (3) is resolved and the VR motion compensation options become more reliable.
  3. Andres Castaneda
    Andres Castaneda Member
    Colombia
    310Coins
    154,750Coins
    +11,196 / 57 / -2
  5. Andres Castaneda
    Colombia
    310Coins
    Vive.
    Thx
  6. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,946Coins
    Using Dofreality with Rift + motion cancellation, but have been disappointed by reliability. Loss of sync with the controller mainly, despite multiple placement relocations. Also i'm having trouble isolating the bass shaker vibrations from the controller.
  7. Andres Castaneda
    Colombia
    310Coins
    Definitely the problem comes from the vibrations of my bass shakers. Turning off the amp the problem disappears immediately.
  8. Andres Castaneda
    Colombia
    310Coins
    @Radioproffi Do you think there is a possibility to change the motors of the platform for actuators? How difficult this could be?
  9. Radioproffi
    Lviv
    1,678Coins
    Do you mean to change gear motors for linear actuators?
  10. Andres Castaneda
    Colombia
    310Coins
    Yes.
  11. Andy Booth
    Andy Booth Active Member
    Malaysia
    430Coins
    Following on from the last post,
    Ive been using the DofReality 3Dof P3 rig for a few months now. Been tweeking and adjusting the rig until I have a good balance point.
    Problem is because the rig is balanced now I can really feel the slop in the motor reduction gearbox.
    Anybody any idea if there is a way of reducing the slop in the gearbox?
    Alternative option would be replace with linear actuators. I'm imagining the linear actuator running horizontally with a bellcrack that converts the horizontal movement to vertical movement. I could also attach the feedback pot to the bellcrank giving the feedback needed (Im assuming that I wold still need that positional feedback.
    Any thoughts or suggestions.
    Andy
  12. noorbeast
    154,750Coins
    +11,196 / 57 / -2
    A slight weight bias on the motors will help with wormdrive free play.
    So does having the smallest CTC on levers that still meets your performance goals, the bigger the CTC distance the now noticable the play in gearboxes.
  13. Andy Booth
    Malaysia
    430Coins
  14. noorbeast
    154,750Coins
    +11,196 / 57 / -2
    Center To Center, the distance on the lever from the center of the motor shaft to the center of the hole where the rod joint bolts to the lever.
  15. Javo5
    Javo5 Active Member
    Buenos Aires, Argentina
    300Coins
    Hello, do you have any clients in Argentina, if possible in Buenos Aires? I would like if possible to see and test the product
  16. Andres Castaneda
    Colombia
    310Coins
    Hola
    Javo.
    Vivo en Colombia y tengo el Dynkit Home Version.
    Si tienes alguna pregunta con gusto la respondere.
    Saludos.
  17. Javo5
    Javo5 Active Member
    300Coins
    Gracias Andrés! Luego te hago unas preguntas
  18. Javo5
    Javo5 Active Member
    300Coins
    Andrés, la principal duda que tengo es respecto al movimiento completo. Yo me armé un simulador casero 2dof donde se mueve solo la silla, al estilo simxperience, que tal funciona este respecto al otro?
  19. Daniel Ng
    Daniel Ng New Member
    Singapore
    140Coins
    Hi @Radioproffi your kit looks awesome!! I am very interested in purchasing it.
    May I please ask how much the full kit will cost (and what does it come with)? I am also wondering if the kit comes in 3DOF? Appreciate your reply. Thanks!
  20. noorbeast
    154,750Coins
    +11,196 / 57 / -2
    Go to the very first post of this thread, the product link is there.
