Looking for some one that can with arduino code
Discussion in 'New users start here - FAQ' started by Anguspogo, Apr 21, 2014.
  1. Anguspogo
    Anguspogo New Member
    406Coins
    AC motor, SimAxe, Arduino, 4DOF
    Hi to all this is my first post
    I am no programmer and i learn by example i am good with my hands but not much between my ears if you no what i mean
    Ok i have an arduino leonardo connected to a stepper driver (microstep driver DQ542Ma)[​IMG]
    which is connected to a Nema 23 stepper motor
    I can make my stepper motor move with this code
    int Distance = 0; //record the numder of steps we've taken
    void setup() {
    pinMode(8, OUTPUT); //dir
    pinMode(9, OUTPUT); //pul
    digitalWrite(8, LOW);
    digitalWrite(9, LOW);
    void loop () {
    digitalWrite(9, HIGH);
    delayMicroseconds(33); // change value for speed fast 33 to 10000 slow
    Distance = Distance + 1; //record this step
    // check to see if we are at the end of our move
    if (Distance == 2000) //2000 steps = 1 complete turn
    //we are Reverse direction (invert DIR signal)
    if (digitalRead(8) == LOW)
    digitalWrite(8, HIGH);
    else
    Distance = 0;
    delay (500);
    which works fine motor can go back and forth one full turn and i can change value in the delayMicroseconds(33) to slow the speed down and also control the amount of turns by changing my distance value
    simtools works fine with the falcon4 bms plugin
    In the tuning center on the first box Roll the numbers go up and down as they should when i play the game the range of numbers is max 32767 to min -32767
    I am only trying to get 1 axis to work the rest will come later If i can get it to work i will be buying a bigger stepper motor to run my sim i am looking to build some think like this
    www.youtube.com/watch?v=-JrvLWvcMhc
    i know i have to use code like
    Serial.begin(9600);
    if (Serial.available())
    and i have been trying for about 2 weeks now to make my motor to turn but with no joy
    so any help would be most welcome
    Thank you for your time in reading my post
  2. SeatTime
    I cannot help you, but that sim in the video is nuts..:D
  3. kermit76
    kermit76 New Member
    The Netherlands (Zwolle)
    357Coins
    I hope to build somthing like that with the Arduino uno.
    I will follow this thread for information for the project i want to start.
    I believe that you need the simtool and the plugin for flightsimulator.
    I downloaded simtool but I didn' t have the time jet to find out how it works.
  4. eaorobbie
    20,494Coins
    Im just finishing a motion capture code for the ard to capture 6dof motion for a new coming app.
    I have a basic code for driving a simular setup that I can share.
    What is needed to be adapted to your code is to be able to read the serial port , which SimTools can send the info too. Then it needs to decide how far and how fast it needs to move the lever to the correct position.
    Check this code we did a while back, very effective in reading the data from simtools.
    SimTools is set to output Rxxx~Lxxx~ where xxx is a value of 0-255. The can be ramped up to 16 bit 0 - 32767 to allow for finer resolution too, just needs to read 5 values and not 3.
    Hope that helps you along, if needed I can look more into it for you tomorrow.
  5. eaorobbie
    20,494Coins
    ps lookup the AccelStepper library for the Ard much easier to use.
  6. Anguspogo
    406Coins
    Thank you for your help I cannot look at it at the moment as I am away on a 3 day holiday with my wife and I am typing this on my iPhone
    Will reply in a few days when I can open on my PC
    Thank you again for your time in helping me Just cannot what to get back now to try it out
  7. kermit76
    kermit76 New Member
    357Coins
    Hello eaorobbie,
    Do you have a link to the post where you use the simtest?
  8. BADDERICK
    BADDERICK Another Member
    Sunny California
    319Coins
    2DOF, 3DOF, Joyrider, Motion platform
    That simulator in the video is awesome! :thumbs
  9. eaorobbie
    20,494Coins
  10. eaorobbie
    20,494Coins
    How did we go mate, any news, any problem need fixing. ?
  11. kermit76
    kermit76 New Member
    357Coins
