Looking for a motor coupling, 19mm to 10mm for SFX 100
Discussion in 'Motor actuators and drivers' started by Moe Colontonio, Feb 9, 2021.
  1. Moe Colontonio
    New Jersey USA
    825Coins
    Hiya guys. I'm building a set of SFX 100s to move a heavy rig (600+ lbs). I've got the SFX100s built, and bought 110ST motors and made adapters to mount them. The last piece of the puzzle here is to find some shaft couplings. The 110ST has a 19mm (3/4") shaft, and the ball screw shaft on the SFX100 is 10mm.
    I've been searching high and low, and the only couplings I could find for 19mm to 10mm are very expensive oldham type couplings. From McMaster I'm looking at $91 per coupling!
    Any advice here is appreciated.
    TIA
  2. John Beardmore
    John Beardmore New Member
    54Coins
    Turn a spacer for the end of the screw to increase its diameter. I would guess it’s easier to find a 19 to 19 coupling.
    Use Loctite 638 to hold the spacer in place. It has a shear strength of around 25 N mm2.
    I am holding the quick release onto my small mige with it for my steering.
  3. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
  4. cfischer
    Colorado
    2,807Coins
  5. Moe Colontonio
    New Jersey USA
    825Coins
    In the end, I bit the bullet and spent $360 on US made Oldham style modular couplings. The downside is they will require me to cut down the motor shafts, which isn't much of a deal I've done it many times before. The upside is they will last a lifetime...
