Linear actuator with 1,8 Kw AC servo motor
Discussion in 'Motor actuators and drivers' started by jsoftware, Nov 14, 2020.
  1. jsoftware
    jsoftware New Member
    IT
    190Coins
    3DOF, AC motor, Motion platform
    My 3DOF platform with three AC servo motors and gearboxes works well. Now I am building a linear actuator using this motor. Final goal is a 6DOF platform based on this new actuator.
    Power: 1,8 Kw
    Displacement: > 200mm
    Maximal linear speed: 500 mm/s
    Size: 720 mm x 120 mm
    Weight: 18 Kg
    Ball screw: 16 mm
    Step: 10 mm
  2. Ads Master
    Ads Master
  3. SeatTime
    Newcastle Australia
    27,868Coins
    DC motor, AC motor, Arduino, Motion platform, 6DOF
    Looks solid :thumbs
    I used 1.8kw servos on my new rig and only regret not going for the 2010 screws instead of the 2005 that I have fitted. The servo certainly has the torque to push the 2010 even with a heavy rig.
  4. jsoftware
    IT
    190Coins
    Yeah, really powerful servo and has reasonable price. I like it very much. But you can easily replace your 2005 with 2010 if you want to :)
  5. cfischer
    Colorado
    1,318Coins
    I have 10mm pitch actuators and I recommend you go 2025 if/when you upgrade with the travel you're looking at.
  6. SeatTime
    Newcastle Australia
    27,868Coins
    1250mm/sec....:eek:.
  7. jsoftware
    IT
    190Coins
    hahah... no, thanks. That's gonna be a catapult simulator. Racing on this thing can be dangerous. Besides, for 25mm step one should take more powerful motors
