Request (Feature) LFS motion 2DOF problem - please help
Discussion in 'SimTools DIY Version' started by TPS, Oct 25, 2014.
  1. TPS
    TPS Member
    Business coach
    Lodz/Poland
    439Coins
    2DOF, SCN5
    Hallo
    I am having problems with my motion 2DOF (prosimu.com, 100 mm actuators based)
    I use Lince (former E69) software to power my 2DOF, which works perfectly with iRacing and Assetto. But it does not work with LFS. I was told by prosimu.com to change CFG.TXT file in LFS folder with these settings:
    Conn To Master 1
    OutSim Mode 1
    OutSim Delay 1
    OutSim IP 127.0.0.1
    OutSim Port 4123
    OutSim ID 0
    OutGauge Mode 1
    OutGauge Delay 1
    OutGauge IP 127.0.0.1
    OutGauge Port 4124
    OutGauge ID 0
    I did it but still no movement.
    Maybe some of you are able to help me please.
    Tom
  2. RaceRay
    23,838Coins
    Hi TPS,
    this is the best timepoint to give SimTools a try;-)
    Maybe some of our members have a hint for you about this issue. Otherwise i suggest to ask directly Fernando, the creator of E69.
    Best,
    René
  3. TPS
    TPS Member
    Business coach
    Lodz/Poland
    439Coins
    2DOF, SCN5
    I asked Fernando - but ro reply from him :(
  4. TPS
    TPS Member
    Business coach
    Lodz/Poland
    439Coins
    2DOF, SCN5
    I downloaded the SimTools but it is not working, probably I did not define something. Finally I got Lince running, a bit jerky but running. The problem is that if I run Lince and SimCommander 4 for SimVibe the cfg.txt changes to its previous values. If I run Lince alone the 2DOF work.
    Perfect situation is I can have both Lince and SC4 running well. Any suggestions are welcome
  5. boboghost1
    boboghost1
    me too......after I have finished according to the tutorial ,but the "sway"and"surge" were very messy,kept shaking.......help!
    145,034Coins
    +10,776 / 52 / -2
    Post your settings and if possible a video.
