just how do you select motors?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Mark Nalder, Aug 6, 2016.
  1. Mark Nalder
    Mark Nalder Member
    England
    646Coins
    Hello
    I found these wheelchair motors on eBay uk
    But no mention of the gearing 1/30. 1/60. That I've read all about in the FAQ here.
    Nothing on the labels in the photo . so just how do you know what's suitable?
    ebay item… 201639462149
    Ta
    Vass
    150,758Coins
    +11,019 / 55 / -2
    You do need to know the full specs and a particular design.
  3. Mark Nalder
    Mark Nalder Member
    England
    646Coins
    OK, so reading here - preferred seems to be 160W 160-200rpm 1:30 ratio 12V
    I just need to find the seller that knows that info of their motors for sale
    (not hopeful)
    150,758Coins
    +11,019 / 55 / -2
  5. Cartti
    Cartti Member
    Finland
    158Coins
    3DOF, AC motor, Arduino
    I did my calculations based on torque and lever arm lenght. When you have those two you can easily calculate how much weight does it lift. After that you can calculate speed of movement and see if it is enough for you.
