Jareks construction with electric actuators
Discussion in 'DIY Motion Simulator Projects' started by jarek, Nov 6, 2007.
  1. jarek
    jarek New Member
    Hi
    Electric actuators are usually expensive
    Once I tried uses engine of car's doormat but he was behind weak
    Now I built own Electric actuators
    It is trapezium screw and electric engine from car's radiator.
    It looks this so
    http://www.youtube.com/watch?v=C_T8am58_rs
    [​IMG] [​IMG]
    I think that one should to match suitable inclination of screw and strength/speed of engine.
    Did someone make something similar?
    What are your ideas?
  2. tronicgr
    tronicgr
    Hi Jarek
    Hey this is a nice and compact linear drive solution! If I had the tools to make something like this at home, I wold definitelly make them!
    Thanos
  3. SimHawk
    SimHawk Member
    Engineer
    Norway
    Good work Jarek,
    Do you have some performance numbers for your actuators? Like speed in mm/s?
  4. jarek
    jarek New Member
    I do not have interface
    I tested only manual, I used battery 12V and 24V It looks well
    I think above use of 2 AC engine or different screw
    I want to test earlier this what do I have
  5. tronicgr
    tronicgr
    Can you post some more pictures? Including some of the overal contruction of your simulator, like the one on your avatar!
    Can you measure its extension, retraction speed? Even if you power it manually...
    If it fast enouph then it could be nice and cheap solution.
    Thanos
  6. jarek
    jarek New Member
    I made short video
    This is not full speed, batteries are not full loaded.
  7. egoexpress
    422Coins
    Wow, thats much faster than I thought it would be!
    Could you tell me the pitch of the thread/nut?
  8. SimHawk
    SimHawk Member
    Engineer
    Norway
    That was very promising! I saw some threaded rods at my local hardware store, maybe I'll pick up a few and make a similar test construction. Good work! :top:
  9. tronicgr
    tronicgr
    From I what I see in the video, your linear actuators are really fast!
    Good job!
    Can you measure their kg performance (ability to lift weights)?
    Thanos
  10. jarek
    jarek New Member
  11. RaceRay
    23,892Coins
    WOW, very fast. Do you powered with 12 or 24V in the video? I think your actuator is a well done alternative to the frex´s ones.
    Unfortunately in poland the trapez... are expensive same as in germany.
    regards René
  12. EvanF
    EvanF Member
    Multimedia Producer
    New Zealand
    423Coins
    Wow, awesome... well done!! :top:
  13. kjg71
    kjg71 New Member
    Designer
    Toledo, Ohio - USA
    9Coins
    yes...very well done
    I watched your video and are surprised as well at the speed. I never thought of using a radior fan motor but I bet it turns fast. Those are made for 12V but are you running 24V at it?
    also not sure on your mechanics, but it looks like you welded the end of the motor shaft to the threaded rod?....and then are threading it with some parts welding in place so they pull solid brackets along?
    ....was wondering what parts move and what parts are stationary ....was trying to figure it out from the picts
    Regards
    Kyle
  14. Duke962
    Duke962 New Member
    Great job, respect ! It´s very fast (too fast) and makes less noise than my frex...
