Is 45kg.cm of torque enough for sim driving?
Discussion in 'DIY peripherals' started by celicaraptor, Feb 29, 2020.
  1. celicaraptor
    celicaraptor New Member
    94Coins
    I want to build a generic purpose FFB steering wheel,mainly ETS2 and maybe some racing games.I have found this motor JGB37-540B which has stall torque of 45kg.cm at 200rpm and 12V 3A.Would i get an adequate amount of force feedback?Say to a logitech g27/g29?
    Thank you
  2. Gadget999
    11,947Coins
    that is not a direct drive motor - it is a geared motor and is not suitable
  3. celicaraptor
    94Coins
    How is it not suitable?Most steering wheels have a dc motor and some gearing to increase it's torque.This achieves the same thing.Please be more precise.
  4. Gadget999
    11,947Coins
    the direct drive wheels have no gearbox
    effort is required to turn the gearbox and this will create a strong resistance - there will be no sensitivity in the feedback
  5. celicaraptor
    94Coins
    Yeah but all wheels that are not direct drive have a gearing to increase their torque.How is this any different?
  6. Sieben
    Sieben Active Member
    2,241Coins
    Not all gearings are created equal) May depend.
  7. celicaraptor
    94Coins
    thats true
  8. Gadget999
    11,947Coins
    try it - it may work
    what is the gear ratio ?
  9. celicaraptor
    94Coins
    It's 30:1.The problem is that i don't know if the sensor measures CW and CCW movement.The seller says that it measures neither which is probably false,else why would it have a hall effect sensor module.So his words are not to be trusted.I am trying to avoid having to buy an external rotary encoder.
  10. HCR Mad Bull
    HCR Mad Bull Member
    439Coins
    DC motor, AC motor
    If it's an actual gear with cogs, then small movement of the wheel or ffb will be horrible, as with cogs there are small gaps between them which will reduce the feeling a lot.
  11. celicaraptor
    94Coins
  12. celicaraptor
    94Coins
    I think they have helical gears,from what i have seen in some teardown videos.
