Iracing mazda
Discussion in 'X-Sim² profiles' started by Nima, Mar 18, 2011.
  1. Nima
    Nima Member Gold Contributor
    Glaser
    Bad Zwischenahn
    532Coins
    hi,
    you must change your scn5 settings is make for scn6.is with slider.if only work one side than you must load again and than its work.is a problem with older versions from x-sim
  2. bleco
    bleco Member Gold Contributor
    IT Problem Coordinator
    Montréal, Canada
    258Coins
    What needs to be changed in the scn5 settings exactly?
    Thx!
    Bleco
  3. Nima
    Glaser
    Bad Zwischenahn
    532Coins
    hi bleco
    you only must change to your speed and aculation in scn5 plugin.the scn6 work with
    the scn5 plugin but can go only 7500 speed.and look for the percentskaler in the end from the profil.
    i have 200mm scn6 on this section.
    you can delite all math botten on the slider and test effect for effect.you must see it as a profiltempler.you only must use the slider.
  4. bleco
    Montréal, Canada
    258Coins
    Huge profile Nima! :eek:
    very complete effects control, thank you very much for sharing your work :yes:
    Bleco
