Iracing game Patching path?
Discussion in 'SimTools Plugins' started by Bruce, Jul 5, 2016.
  1. Bruce
    Bruce CM Security
    Security Tech
    townsville
    718Coins
    Can someone point me to the correct path file to patch iracing??
  2. Chumet1
    Chumet1 Member
    - 2Coins
    2DOF, JRK
    I'm in the same situation. It gives me error when patching iracing. I point to the installation path, in my case it is in the root of one of my HDDs, iRacing folder. As a game that starts from the browser is there another route more appropriate? Or I'm not using the correct plugin. I still use Simtools 1.3 and he had downloaded the plugin: iRacing_Plugin 1.0.5.2. IRacing is a new game for me, recently installed since yesterday. Thank you
  3. yobuddy
    51,393Coins
    I believe IRacing got updated and the 1.3 plugin does not work anymore?
    Could someone confirm this that is still on 1.3.
  4. Rodrigo Baornio
    Rodrigo Baornio New Member
    Brazil
    - 285Coins
    here 1.3 too and dont works patch more, what i need to do?
    153,107Coins
    +11,117 / 56 / -2
    The plugin will need to be updated, so you will need to be patient for a bit until @value1 gets it done.
  6. Rodrigo Baornio
    Brazil
    - 285Coins
    Ah ok, do you know if the plugin en simtools v2.1 is working?
    2 weeks ago iracing remove 32bits suports and dx9. Now only dx11 and 64bits, maybe this cause the problem.
