Info about relais card
Discussion in 'SimTools compatible interfaces' started by Cinauz, May 18, 2009.
  1. Cinauz
    Cinauz New Member
    Hello, my project is almost finished, I have a question to go ... I did not need to control the speed and acceleration, I have seen in the pattern of x-sim you can connect a DC motor directly to a relay card, correct?Here:
    http://www.x-simulator.de/beta/electric.html
    I have only on-off engine, correct? If possible, the card is compatible velleman or do I need the VM110? I have to put poti or not necessary? Sorry so many questions .. Help me, pleeeeaseeee.....Thank you all! Denis
  2. pointer4
    pointer4 Member
    Hungary
    276Coins
    There is some misunderstanding according to me.
    From among three solutions which one you want to use:
    - Wiper motor with Thanos electronics
    - Velleman k8055 panel, with pneumatics
    - with SCN5 actuator
