info about ballscrew - technical part
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by tronicgr, Sep 4, 2008.
  1. tronicgr
    tronicgr
  2. egoexpress
    Thanks,
    very describing!
    Regards
    Christian
  3. tronicgr
    tronicgr
    Since sometimes, good info pages get lost or unavailable, I decided to preserve it here in PDF document:
    ballscrew_technical_info.pdf
    And you can print it too if you like :thbup:
    Regards, Thanos
  4. egoexpress
  5. Fahim
    Fahim Member
    553Coins
    Dear sirs,
    Seems interesting.
    What is a ball bearing screw? I have seen video.
    What does it do?
    Kind Regards.
  6. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,801Coins
    Hi Fahim
    The grey pices are the ball bearing screws
    Bleu is the nut
    They sit in actuators like scn5
    The motor sits on ballscrew makes him rotate,and makes the nut move,on the nut sits the pushrod.
    And the actuator moves in and out. :thbup:
    regards Ad
  7. egoexpress
