  4. All new posts and threads should be written in English. Please do not create dual posts in other languages. If you are not a master of the English language you can use an external service to create a translation of your words, for instance, Google translate or DeepL.
    Due to low activity, we've also closed the french section.
Inconsistent SMC3 connectivity to Arduino
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Sam Neall, May 11, 2020.
  1. Gadget999
    Gadget999 Active Member
    6,364Coins
    what is the SPS part of the SMC3 ?
    what does connecting pin 8 to gnd do ?
    108,793Coins
  3. Sam Neall
    Sam Neall Member
    294Coins
    Sorry nobody asked me what sketch I was using. Since I had no clue what the problem was (axis configuration, SMC3, wiring, tuning center) I just posted it on the general questions thread. My bad.
  4. Sam Neall
    Sam Neall Member
    294Coins
    I think setting the smoothing parameter too high previously caused the main problem for me because it seems to be better with a lower Ks. Increasing deadzone makes the PWM line stand still when the motors aren’t moving, but as soon as I try and move the motors, there is worse twitching. Increasing Fpid/ seems to do nothing beyond 4 which slightly makes it better.
  5. BlazinH
    15,509Coins
    In my case I didn't ask what sketch you were using because the threads title says your issues are with SMC3 sketch not SMC3-SPS :confused:. That was the point of my previous post.
  6. Sam Neall
    Sam Neall Member
    294Coins
    Y
    Yeah I didn’t know what SPS meant so I didn’t know I needed to make a distinction haha.
