improving immersion
Discussion in 'SimTools compatible interfaces' started by alpefe, Nov 30, 2012.
  1. alpefe
    alpefe Member
    - 17Coins
    This is something that I will not bring it to market here, is an affordable way to improve the immersion in the game, it is simply put a cover it is more likely that either black or gray PVC foam is a lightweight material and cheap, clean and very well insulated from outside of you so that you concentrate only on the screen.
    the system is simply a strip of aluminum 3X30, but may be any other material, we can manipulate this action when either conform to our taste, and not expensive.
    We set our monitors support, bend over and we monitor 2 M4-M5 holes to fasten PVC plate.
    as you will see in the render, if only utilizais a monitor or TV, also want to put on the sides will find that after a while of playing will win in immersion and concentration, which will be translated into better times, I hope you like it.
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  2. mad_marty
    mad_marty Member
    Machinist
    709Coins
    I thought about it, too. People underestimate how important it is to shield the especially moving platforms from the static environment. I thought about using a big umbrella for the roof and cloth for the sides so I don't have a big weight disadvantage.
  3. maximizador
    maximizador New Member
    farmer
    Galvez Argentina
    360Coins
    I think a great idea to remove distraction . I also think it is important the relationship of the position of the image as in this video
  4. GTHQ_koop
    GTHQ_koop Active Member
    Something with airplanes..
    Lakehills Texas USA
    1,786Coins
    2DOF, SCN5
    Has something similar but waaay to hot in the summer even after installing 3 fans..
  5. Pit
    30,512Coins
    Nice! The only thing I don't like the wheel and hands are "covered" by the projector.
  6. Pit
    30,512Coins
    BTW after racing with triples I would never go back to 2D, Nvidia 3D surround is somewhat of buggy but at the moment the best alternative to the VR, despite of the lower resolution (in comparison with VR) but you think you sit in the car and not in front of the screen.
