I cant take FFB with Arduino Leonardo
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by ozkan memisoglu, Oct 27, 2019.
  1. ozkan memisoglu
    ozkan memisoglu New Member
    87Coins
    I can play on ACC but I cant take FFB what I do wrong :S What should I do. Wheelcheck doesnt work :S. Im using FFBWheel.0.16.leonardo.hex
  2. Qlittles
    Qlittles Active Member
    Union City, California, USA
    226Coins
    I have a "Cousin of OSW" direct drive wheel -- for my build, I have the main gain set to 100%. I also have all the other values under Game Effects to 100%, like Spring, Friction, Damper, etc. I don't know the specifics of your build, so try raising the main gain 10% at a time and try the game in ACC
  3. MarcoMade
    MarcoMade Active Member
    italy
    157Coins
    ozkan memisoglu
    you should give more information about it.
    if with other games it works for example. if by setting desktop effects to 100% spring responds with force.
    otherwise if everything works the main gain goes to 100%.
    and the problem is in ACC in the peripheral setup
  4. JohnSellote
    JohnSellote New Member
    6Coins
    do you guys have download link for FFBWheel.0.16.leonardo.hex?
  5. MarcoMade
    italy
    157Coins
    if the moderators give me permission I can insert it in this post in order to make it accessible to the community
