Question Huge FPS drop in VR with simtools
Discussion in 'SimTools Pro & Entertainment Version' started by splendiddd, Sep 18, 2019.
  1. splendiddd
    splendiddd Active Member
    CCTV security
    Netherlands
    810Coins
    Hi Guys,
    I am using a Pimax 5k+ for a while now and i noticed that i lose 20 to 30 fps in for instance Assetto Corsa when simtools is running.
    I use a DOF Reality P3 and the other software for this motionrig from simracingstudio does not have this issue.
    But i want to keep using simtools because it has more options for profile making.
    It drops from steady 90 to 70 to even lower when game engine is running for motion.
    Specs:
    intel i7 4790k 16GB ram SSD asus sabertoothe mkii etc
    Win 10 pro
    GTX 2080ti Gigabyte Gamer edition
    Any ideas? BTW i run simtools 2.3
    150,548Coins
    +11,017 / 55 / -2
    I have found the Pimax does benefits from tweaking individual game settings. What have you done to dial AC in for it?
    The only real impact I can think of that any motion software would have is CPU, where the hardware is marginal and a borderline bottleneck.
  3. splendiddd
    CCTV security
    Netherlands
    810Coins
    Ok but why does the other software not impact fps at all? must be sort of bug.
    I have also simhub and simvibe running
    Pimax settings are normal FOV 1.25 all other stuff off in PITool
    Steam @80% Supersampling
    Super smooth without simtools runnnig, with its around 70 instead of 90.
    Really weird. Can i upgrade without losing profiles and settings to 2.4?
    Regards, Rob
    150,548Coins
    +11,017 / 55 / -2
  5. yobuddy
    50,290Coins
    Maybe a port conflict?
