Question How to use simtool continuously with the lease restart and setting
Discussion in 'SimTools Pro & Entertainment Version' started by COGO, Jul 4, 2017.
  1. COGO
    COGO New Member
    - 159Coins
    When I use simtool 2 in a game, i have to restart simtool because of loosing connection and data. I want to make this software plug&play with the minimum setting. I appreciate any help
    Ako
    150,686Coins
    +11,018 / 55 / -2
    You need to provide more detail, if you are loosing connection then there is a reason why and you need to determine what that is and fix it.
    Please explain all of your hardware and post pictures of all settings.
  3. COGO
    COGO New Member
    - 159Coins
    I found the problem for crashing, loosing wire connection! But I look for a solution to make startup as simple as possible. So an operator can run the simulator without many setting.
  4. yobuddy
    50,358Coins
    Once a game is patched, SimTools just sits in the systray and "auto starts" when the game is launched.
    SimTools can even auto start with windows.
    So I think you will be good to go.
