Question How to protect your IBT_2?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Design89, Jan 14, 2023.
  1. Design89
    Design89 Member
    Netherlands
    214Coins
    I'm using wheelchair motor's 22,5 volt 17,5 amps and 24 volt 25 amps power supply. With some IBT_2's.
    Each motor has his own PS and IBT_2. It did work for like a few minutes and then the IBT_2 failed...
    Now I did test it with a 12V battery as a power supply and it works fine.
    How can I protect the IBT_2 when using the 24 volt PS (turned it down to 22V)?
    I have some capacitators 2200uF 25V laying around. Should it be enough to put 2 in series and then several pairs in parallel to protect the IBT_2's or is there a better solution instead of a battery?
  2. Gadget999
    11,941Coins
    It probably shut down due to overcurrent or over temperature
    If you turn it off and on again does it now work ok ?
  3. Design89
    Design89 Member
    Netherlands
    214Coins
    Unfortunately no, one IBT is already broken @Gadget999. It turns in only 1 direction at full power..
    Could be some power delivered back from the motor? Or the IBT has both bridges open at the same time?
    Got 2 left now and testing with the 12V battery, that works fine.
  4. wingert
    wingert Active Member
    642Coins
    4DOF
    look in data sheet about the spec, and replace it with other type which can deliver more current and voltage, and use same heat sinks.
  5. Design89
    Design89 Member
    Netherlands
    214Coins
    IBT_2 should handle up to 43A and 27.5V. They have already heatsinks on them.
    That's why I suggested some capacitators 2200uF 25V laying around. Should it be enough to put 2 in series and then several pairs in parallel to protect the IBT_2's.
    Do you have a better suggestion?
  6. wingert
    642Coins
    4DOF
    If IBT2 is a FET there are plenty that can deliver more current 80-160A and voltage.
    Consider switch on current which can exceed the limits.
  7. Design89
    Design89 Member
    Netherlands
    214Coins
    Do you have an example that doesn't cost 100 euro each?
    Those IBT_2's are used a lot here, but I cannot find a good solution.
  8. wingert
    642Coins
    4DOF
    N-CH MosFet IRF 1404, 40V 162A, some electronic provider offer the possibility searching for current and voltage.
  9. Design89
    Design89 Member
    Netherlands
    214Coins
    Searching on the internets I came across this possible solution with capacitators.
    https://www.electrical4u.net/induction-motor/single-phase-motor-capacitor-calculation-calculator/
    In my case I would need capacitors around 50V 2200µF for my 330 watt motors. I have 25V 2200µF capacitors. So I will try to put 2 in series and 2 of those in parallel, 4 in total for one motor. That should make 50V 2200µF. I did use 80% for motor efficiency.
    And for my 235 watt motors it would be 1200µF, so only 2 in series would do it I hope. Missing only 100µF in that case.
    I will try this theory hopefully this week somewhere and post the results here.
    At the moment busy with some design changes. I have to finish that first before I can test properly.
    For those who are interested: https://www.xsimulator.net/community/threads/diy-sim-from-wheelchair-parts.17453/
  10. Gadget999
    11,941Coins
    every time you motors change direction the capcitor will be discharged and then charged again in the opposite direction - you may need to fit them across the powersupply not the motor
  11. wingert
    642Coins
    4DOF
    common switch-mode power supply design have this capacitors, so he enhance his power supply.
  12. Design89
    Design89 Member
    Netherlands
    214Coins
    Nice option, only thing is that at this moment I do not want to build my own moto drivers like an IBT_2.
  13. Design89
    Design89 Member
    Netherlands
    214Coins
    I will try this later.
  14. Design89
    Design89 Member
    Netherlands
    214Coins
    But will it protect my IBT_2 that way?
  15. Allwin Joseph
    Allwin Joseph ajstan
    Student
    Bengaluru,India
    12Coins
    Check your motor's current draw with a clamp meter, Also check if the ground is isolated, IBTs fail when the ground isnt isolated.
