How to choose a force feedback motor
Discussion in 'Motor actuators and drivers' started by dynamowtf, Aug 19, 2021.
  1. dynamowtf
    dynamowtf New Member
    34Coins
    Hi everyone, I'm looking to develop a fishing simulator. I wanted to create something similar to "SimFish"(video below min 12:00).
    I had thought of using a motor to drive the line with a cylinder to emulate force feedback.
    I would like your advice on where I can read more about which motors can be used for ffb, as the motor will be turning in the opposite direction of the engine most of the time (which a normal motor would cause high temperatures or destruction of the motor?).
    It would help me if you could give me some advice on the choice of motor, or if there are any topics or pages where motors for ffb are discussed in more depth. Also how to choose the torque so that it is not too excessive or too weak, so that it can be moved in the other direction manually.
    Video min 12:00
  2. roarfun
    roarfun New Member
    12Coins
    Hi, which system do you use for it?
