Question how come my htc vive have no sound
Discussion in 'VR Headsets and Sim Gaming - Virtual Reality' started by marlon, May 29, 2018.
  1. marlon
    marlon Active Member
    1,070Coins
    how come my htc vive have no sound it on b and c and sound is not working
    153,890Coins
    +11,154 / 57 / -2
    Check the seating of all cables both ends and the SteamVR and computer sound settings.
  3. Zed
    USA
    5,845Coins
    Hey Marlon, when people talk about b and c with the Vive, they are generally referring to the Lighthouse setup when running without a sync cable. Those letters show up through the lighthouse lenses and you set them with a button on the back of the Lighthouse.
    With no sound, Noorbeast is right - it sounds like your computer settings. Check in SteamVR audio settings and see if you have audio directed or mirrored to the Vive. And with SteamVR running, check the volume level set for the Vive. You won’t see that setting unless SteamVR is running because the computer can’t see the Vive audio without it.
  4. Brett Horton
    Brett Horton Active Member
    Program Manager / Pilot
    Tampa FL
    118Coins
    If HTC Vive home audio works but not in app, then probably need to select USB Audio device on your computer NOT HTC VIVE Audio.
    I have this same problem on my laptop with the Vive.
