Question How Can I Make A Steering Wheel With This Parts
Discussion in 'Motor actuators and drivers' started by seri13, Oct 1, 2020.
  1. seri13
    seri13 New Member
    44Coins
    I have Arduino Leonardo, TB6600 and Nema 17 stepper motor. Can I make a steering wheel and How ?
  2. knaufinator
    knaufinator Active Member
    Simulation Engineer
    akron,ohio
    1,955Coins
    AC motor, 6DOF
    Most DIY wheels are using AC servos, not Stepper motors, you also need a rotary encoder on the motor for position feedback most stepper motors do not have them but you can find some that do.. I think they are called Hybrid steppers.... The NEMA 17 is a tiny stepper motor, they have very tiny torque capabilities compared to what is used in a wheel. I would use what you have as a stepping stone in learning by using the Arduino to instruct the TB6600 to spin the stepper. but these devices are insufficient for a DIY Gaming wheel.
  3. Shadow Nightmares
    Shadow Nightmares New Member
    41Coins
    OpenFFBoard works with stepper motors, but unfortunately its still on BETA, just like all of the other projects with stepper motors
  4. Sam Neall
    Sam Neall Member
    84Coins
    The nema 17 is a bit weak for force feedback (only .59 nm), and you would need some monitoring system for PID control. I agree with what @knaufinator said. You can use this as a prototype. However I'm not sure if it would be cost effective to build your own wheel. You would probably be better off getting a csl elite or, if you want to save some money, a thrustmaster. The G29 is also really good value although it is gear driven.
  5. Gadget999
    12,331Coins
    Stepper motors are not suited to a ffb wheel
  6. noSaint
    noSaint New Member Gold Contributor
    160Coins
    utube has some videos of SimpleFOC and brushless, but also running steppers with the same library. The key is the encoder feedback to automatically adjust torque.
