Help getting values of potentiometer
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by macazaga, Nov 7, 2014.
  1. macazaga
    macazaga New Member
    16Coins
    2DOF, 3DOF, Arduino, Joyrider, Motion platform
    Hi
    I'm building a 2dof flight simulator and i have my arduino sketch that gets the position of the aircratf and maps it to the position of a small servo but now i want to do it with a wiper motor building the DIY Linear Actuators (http://bffsimulation.com/linear-act.php) How can i get the value of the position of and map it to my sketch?
    here is part of the code:
    // Roll
    if (discard == 'R'){ // Found the reading "Roll"
    delay (5); // It seems to need a delay here
    roll = "";
    roll += char(Serial.read()); // first digit pof the data
    roll += char(Serial.read()); // Second digit and so-on
    if (roll != rollold){ // checks to see if its different to the "old" reading
    char carray[7]; //converting a string to number sequence
    roll.toCharArray(carray, sizeof(carray)); //converting string to number sequence
    int n = atoi(carray); //converting string to number sequence
    // maybe the potentiometer value goes here and them map it to the servo
    n = map(n, -90, 90, 0, 179); //Maps the readings to the servo
    myservoroll.write(n); //Sends the data to servo
    rollold = roll; // Writes the current reading to the "old" string.
    } // end of it's a different reading section
    any help will be very appreciated
  2. RacingMat
    21,026Coins
    Help It dépends on what DC driver you intend to use: pwm+1 pin direction
    Or 2 pins direction ?...
    Then you have to change the code accordingly.
    Have a look at my Resources (link below)
    Mat
  3. Mazhar Salam
    Mazhar Salam Member
    Melbourne
    907Coins
    Firstly, you have to implement the POT in such a way that it can read the entire mechanical range of your actuator design. This can be done with the help of gears or multi turn pots. Sketch for servo motors are entirely different and cannot be used. You should be able to use racing mat 2dof sketch as its written for wiper + pot setup.
