help for my simulator
Discussion in 'SimTools compatible interfaces' started by jozyney, Mar 31, 2012.
  1. jozyney
    jozyney New Member
    - 7Coins
    hello my name is joziney am Brazilian, I'm trying to build a simulator like this one that appears in video
    http://www.youtube.com/watch?v=44PU8cZSt_c
    over here in Brazil do not have all the components to build the pcb.
    you guys could tell me if it is possible to use this circuit to the simulator
    http://www.rogercom.com/pparalela/Lpt8M.htm
    Please need some information so I can make my simulator.
    sorry if spelled wrong and why I'm using the the google translator.
  2. bsft
    Hello, to build the joyrider, buy the plans from here http://www.acesim.com/main.html
    For control boards, save yourself the hassle and use the Pololu JRK 12v12 http://www.pololu.com/catalog/product/1393 , one per motor, easy to wire up - 7 wires and one usb cable, simple USO commands.
    For the belt drive set up, dig through the threads, I have seen somewhere several designs to make your own pulley belt/chain drive.
    Hope that helps .
    :cheers: David.
