help connect Arduino and moto monster
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by dualclick, Jan 1, 2015.
  1. dualclick
    dualclick
    Friends wanted to ask a clear pattern for the connection of Arduino, moto monster and pots thanks in advance
  2. Pit
    30,477Coins
    it depends on the code you are willing to use.
  3. dualclick
    dualclick
    Mi sono espresso male, uno schema elettrico tra Arduino e moto mostro
  4. Pit
    30,477Coins
    ah ok, despite I don't speak Italian I did understand now what you are meaning. ATM I do not know if and where are such schematics available.
  5. dualclick
    dualclick
  6. dualclick
    dualclick
    a scheme like this but clearer Asthe I have no idea about the various connections
  7. Pit
    30,477Coins
    hmm, again - what do you want now? :) "uno schema elettrico tra Arduino e moto mostro" is completely different from what you have posted ;) What is your intention, are you asking about the wiring or do you want more details about the boards?
    PS: the wiring scheme is very clear, but which Arduino code are you using?
    PS2: Damned, there is no Arduino - I know this picture, but do not remember where I have seen it.
  8. Daguru
    Kitchen installer
    Wales uk
    454Coins
    Motion platform
    I think this diagram is for when you stack the arduino under the monster moto the diagram shows the arduino as a line drawing under the monster moto.
    Not sure what arduino code you would use though with this set up I guess it would be racingmats
  9. dualclick
    dualclick
    yes racingmat
  10. RacingMat
    21,023Coins
  11. RacingMat
    21,023Coins
    if diagram is not clear enough, just stick to the references (I updated the resource post):
    Arduino /..Motomonster1
    ....GND <-> GND pin
    .........5V <-> 5V
    .....pin 4 <-> pin 4 inA motor1
    .....pin 5 <-> pin 5 pwm1
    .....pin 6 <-> pin 6 pwm2
    .....pin 7 <-> pin 7 inA motor2
    .....pin 8 <-> pin 8 inB motor1
    .....pin 9 <-> pin 9 inB motor2
    .....pinA0 <-> center pin of pot 1
    .....pinA1 <-> center pin of pot 2
    .....pinGND <-> 0 ohm's pin potentiometer 1 & 2
    .....pin 5V <-> 10k ohm's pin potentiometer 1 & 2
