Help changing xsim output to simtools (arduino)
Discussion in 'SimTools DIY Version' started by Mr ed, Nov 9, 2013.
  1. Mr ed
    Mr ed New Member
    Australia
    55Coins
    Hi guys,
    I was after some help getting simtools to connect with my Arduino :S
    The USO output in xsim looks like this:
    sim start: ~171~R~1~~1~~187~
    Axis info: ~171~G~2~~a01~~a02~~187~
    Sim end: ~171~R~1~~0~~187~
    I'm not to sure what to change this to in simtools..
    Jason
  2. yobuddy
    51,383Coins
    We use angle brackets the rater than the tilde key.
    Any number in the angle bracket from <0> to <255> gets replaced with the ascii value.
    So your output would be as follows,
    Sim start: <171>R<1><1><187>
    Axis info: <171>G<2><Axis1><Axis2><187>
    Sim end: <171>R<1><0><187>
  3. Mr ed
    Mr ed New Member
    Australia
    55Coins
    Thanks yobuddy, we have connection!
  4. yobuddy
    51,383Coins
  5. Mr ed
    Mr ed New Member
    Australia
    55Coins
    Hmm i get an error when i open rfactor..
    Microsoft.NET Framework
    Unhandled exception has occurred in your application. If you click Continue . the application will ignore this error and attempt to continue. If you click quit, the application will close immediatly.
    Object referance not set to an instance of an object.
    There is more details under it if you want them.. any ideas?
  6. Mr ed
    Mr ed New Member
    Australia
    55Coins
    This was in the message details:
    System.NullReferenceException: Object reference not set to an instance of an object.
    at rFactor_Plugin.Plugin.ShutDownCommands()
    at SimTools_GameManager.Mod_Lib.GameStoped()
    at SimTools_GameManager.frmMain.tmr_IsGameRunning_Tick(Object sender, EventArgs e)
    at System.Windows.Forms.Timer.OnTick(EventArgs e)
    at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
  7. yobuddy
    51,383Coins
    looks like a possible plugin problem, but why you get this problem and no one else is reporting it seems strange.
    Have you tried any other games?
  8. eaorobbie
    20,491Coins
    Bugger I use rfactor online , Have not seen that one.
    Is it the latest patch on rfactor could be the issue or maybe a custom plugin affecting simtools plugin.
    I would make sure Rfactor is up to date and just as a test remove any other custom plugin and test, if good add the plugins back one at a time till you find the one that upsets SimTools.
  9. value1
    14,184Coins
    As @eaorobbie says: try to remove all the other plugins from the rFactor plugin folder and see if it works.
  10. Mr ed
    Mr ed New Member
    Australia
    55Coins
    Righto i'll give it a go, i tryed rfactor 2 and no errors
  11. Mr ed
    Mr ed New Member
    Australia
    55Coins
    yesterday i tryed a few times and got this error every time, today i took out xsimplugin.dll and tryed it, no error, put it back in, no error.. weird, but it seem to be fine now :S
    1 more question, i havn't been able to find an axis offset adjustment anywhere in the software or the documentation, does it have it anywhere?? or can i somehow put an offset in the output setup? possibly something like <Axis1+200> or something like that?
    Edit: another question :) is it better to run 1 or 2 computers? I remember reading on xsim that it was supposedly not possible to not have a delay using only 1 computer,(for reasons i don't understand) i tested it and there was a delay with 1 computer and none with 2. Is it the same for simtools or is 1 computer fine?
  12. BlazinH
    16,677Coins
    Currently there is not an axis offset slider or a way to adjust your center position with SimTools. However, it is already in the works for inclusion in a future release of SimTools. I can't say whether or not it will be in the next release however.
    SimTools has been optimized for use on one computer. If you wish, you can use a secondary computer to run the game engine on. I am not able to tell you though, if there is any advantage to running on a dual computer system.
  13. value1
    14,184Coins
    With today's processing power 1 computer is fine.
    For usability reasons I run a dual-PC setup for my sim. I can run the games in full (tripple) screen on one PC and fiddle with the GameEngine or with the JRK's on the other PC – which I personally find quite convenient.
    Functionallity-wise there's no fundamental difference.
  14. gigi
    gigi Active Member
    919Coins
    2DOF, JRK, 4DOF
    Hallo I have a similar problem
    Le informazioni su come richiamare il debug JIT (Just-In-Time) anziché questa finestra
    sono riportate in fondo al messaggio.
    ************** Testo dell'eccezione **************
    System.NullReferenceException: Riferimento a un oggetto non impostato su un'istanza di oggetto.
    in SimTools_GameManager.Mod_GameProfileLoader.GameProfileChanged()
    in SimTools_GameManager.frmMain.cb_GameSelection_SelectedIndexChanged(Object sender, EventArgs e)
    in System.Windows.Forms.ComboBox.OnSelectedIndexChanged(EventArgs e)
    in System.Windows.Forms.ComboBox.set_SelectedIndex(Int32 value)
    in SimTools_GameManager.frmMain.frmMain_Load(Object sender, EventArgs e)
    in System.EventHandler.Invoke(Object sender, EventArgs e)
    in System.Windows.Forms.Form.OnLoad(EventArgs e)
    in System.Windows.Forms.Form.OnCreateControl()
    in System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    in System.Windows.Forms.Control.CreateControl()
    in System.Windows.Forms.Control.WmShowWindow(Message& m)
    in System.Windows.Forms.Control.WndProc(Message& m)
    in System.Windows.Forms.ScrollableControl.WndProc(Message& m)
    in System.Windows.Forms.ContainerControl.WndProc(Message& m)
    in System.Windows.Forms.Form.WmShowWindow(Message& m)
    in System.Windows.Forms.Form.WndProc(Message& m)
    in System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
    in System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    in System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Assembly caricati **************
    mscorlib
    Versione assembly: 4.0.0.0
    Versione Win32: 4.0.30319.17929 built by: FX45RTMREL
    Base di codice: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
    Versione assembly: 0.1.2.0
    Versione Win32: 0.1.2.0
    Base di codice: file:///C:/Program%20Files%20(x86)/SimTools/SimTools_GameManager.exe
    Microsoft.VisualBasic
    Versione assembly: 10.0.0.0
    Versione Win32: 11.0.50709.17929 built by: FX45RTMREL
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    Versione Win32: 4.0.30319.34251 built by: FX452RTMGDR
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Runtime.Remoting
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    System.Configuration
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    PluginAPI
    Versione assembly: 1.0.0.0
    Versione Win32: 1.0.0.0
    Base di codice: file:///C:/Program%20Files%20(x86)/SimTools/PluginAPI.DLL
    AssettoCorsaEA_Plugin
    Versione assembly: 3.0.6.0
    Versione Win32: 3.0.6.0
    Base di codice: file:///C:/Users/gigi/AppData/Local/SimTools/GamePlugins/AssettoCorsaEA_Plugin.dll
    DIRT2_Plugin
    Base di codice: file:///C:/Users/gigi/AppData/Local/SimTools/GamePlugins/DIRT2_Plugin.dll
    DirtRally_Plugin
    Versione assembly: 1.0.4.0
    Versione Win32: 1.0.4.0
    Base di codice: file:///C:/Users/gigi/AppData/Local/SimTools/GamePlugins/DirtRally_Plugin.dll
    GRID2_Plugin
    Base di codice: file:///C:/Users/gigi/AppData/Local/SimTools/GamePlugins/GRID2_Plugin.dll
    GTLegends_Plugin
    Versione assembly: 3.0.0.1
    Versione Win32: 3.0.0.1
    Base di codice: file:///C:/Users/gigi/AppData/Local/SimTools/GamePlugins/GTLegends_Plugin.dll
    GTR2_Plugin
    Base di codice: file:///C:/Users/gigi/AppData/Local/SimTools/GamePlugins/GTR2_Plugin.dll
    GTR_Plugin
    Base di codice: file:///C:/Users/gigi/AppData/Local/SimTools/GamePlugins/GTR_Plugin.dll
    iRacing_Plugin
    Versione assembly: 3.0.3.0
    Versione Win32: 3.0.3.0
    Base di codice: file:///C:/Users/gigi/AppData/Local/SimTools/GamePlugins/iRacing_Plugin.dll
    LiveForSpeed_Plugin
    Base di codice: file:///C:/Users/gigi/AppData/Local/SimTools/GamePlugins/LiveForSpeed_Plugin.dll
    rFactor2_Plugin
    Base di codice: file:///C:/Users/gigi/AppData/Local/SimTools/GamePlugins/rFactor2_Plugin.dll
    rFactor_Plugin
    Versione assembly: 3.0.4.0
    Versione Win32: 3.0.4.0
    Base di codice: file:///C:/Users/gigi/AppData/Local/SimTools/GamePlugins/rFactor_Plugin.dll
    RichardBurnsRally_Plugin
    Base di codice: file:///C:/Users/gigi/AppData/Local/SimTools/GamePlugins/RichardBurnsRally_Plugin.dll
    WRC4_Plugin
    Base di codice: file:///C:/Users/gigi/AppData/Local/SimTools/GamePlugins/WRC4_Plugin.dll
    mscorlib.resources
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_it_b77a5c561934e089/mscorlib.resources.dll
    System.Windows.Forms.resources
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_it_b77a5c561934e089/System.Windows.Forms.resources.dll
    ************** Debug JIT **************
    Per abilitare il debug JIT, è necessario impostare il valore
    jitDebugging nella sezione system.windows.forms del file di configurazione
    dell'applicazione o del computer (machine.config).
    L'applicazione inoltre deve essere compilata con il debug
    abilitato.
    Ad esempio:
    <configuration>
    </configuration>
    Quando il debug JIT è abilitato, tutte le eccezioni non gestite
    vengono inviate al debugger JIT registrato nel computer,
    anziché essere gestite da questa finestra di dialogo.
