Help a newbie set up a home-made 6DoF platform
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Geoff M, Sep 14, 2025 at 03:43.
  1. Geoff M
    Geoff M New Member
    18Coins
    Hi folks,
    I'm setting up a 6DoF platform and am completely lost when it comes to the electronic side of it.
    I am trying to use AS5600 Hall effect encoders with Arduino r3 controllers.
    For clarity I intend to use 3 Arduinos and 3 Dual H bridge drivers to drive 6 24VDC 500W motors via a lead acid (car) battery setup.
    These are my sticking points:
    1) I have no idea on how to set up the encoders. I am aware there is a couple of ways to set it up (I2C or PWM). I have no idea which is preferable, or if there is even a choice!
    2) After determining the encoder setup, Do I need to run end stops (eg micro switches), or does the encoder always know where "home" is? Are the limits set in the Arduino code?
    3) How do I wire the AS5600's to the Arduinos for whichever mode is the best. Does someone have a wiring diagram I can reference?
    4) Is there a depository, or downloadable file for the arduino code somewhere?
    Can anyone point me in the right direction as I am keen to get on with the project. I have no programming experience and very basic understanding of electronics, but am trying to wrap my head around it.
    Any help will be greatly appreciated!
