    Buy Download Package Now!
Harness Tensioner
Discussion in 'Commercial Simulators and Peripherie' started by SeatTime, Apr 23, 2018.
  1. SeatTime
    SeatTime Well-Known Member SimTools 2.0 Beta Tester
    Newcastle Australia
    25,654Coins
    Note: See the end of thread for current availability.
    Hi Guys, finally completed my commercial Harness Tensioner (now V2 - changes made in the Power supply, Bowden cable and acoustics), which runs as an interface/2 axises on Simtools. This is a great addition to any simulator; fixed, or with motion. It allows extended braking (surge) mainly for cars and heave effects for aircraft/space craft. These will fit simply to most existing race seats via a adjustable clip that fits over the top harness entry hole - no modifications to the seat are required. The part that fits to the seat is made predominately out of Aluminium and composites to ensure light weight. A Video of it running is in a post below. What is interesting with this setup, is as the belts are independently driven (each can move the harness approx 100mm), you can even mix in some sway:). Does not include Harness, or Simtools license - as most would already have these.
    System - includes, international IEC socket outlet, Large Meanwell Power supply (v2), USB cable, Equipment box (houses controller and Servos etc) and Bowden cable/harness attachment system. Bowden cables length are supplied at a 1M outer sleave length which can be shortened further by the user if required. After the initial batches that I have built to order, I will now only make these in small batches and then offer them for sale. Price is now $530 AUD + postage. If these sell I will make more, if not, I will stop. Unfortunately with all the upgrades parts and my time, this is realistically the cheapest I can make them moving forward. To gauge postage costs from Australia - package weight is around 3.5Kg.
    Big roller version
    Fitted to race seat.
    The seat clip adjusts to different sized harness through hole depths.
    • Winner Winner x 3
  2. AussieSim
    AussieSim Member
    Australia
    1,219Coins
    Hi SeatTime,
    How do you recommend mounting the Equipment box, should it be rigidly mounted to the rig frame and ideally with the Bowden cables straight ? Or can it sit on the floor unmounted.
    If it should be mounted would one drill holes through the box, as I don't see mounting tabs/holes.
  3. SeatTime
    Newcastle Australia
    25,654Coins
    It does not need to be hard mounted to work. It would be fine just sitting on the floor, although you could velcro it somewhere to keep things neat if you like.
  4. sberns
    sberns Member Gold Contributor
    263Coins
    3DOF, SCN5, Arduino
    Looks great! What belt width is it designed for? 3”?
  5. SeatTime
    Newcastle Australia
    25,654Coins
    Yes, 3 inch or less.
  6. SeatTime
    Newcastle Australia
    25,654Coins
    Video of the Seat Tensioner in operation on my old race seat.
    • Like Like x 8
    • Winner Winner x 3
  7. Gadget999
    Gadget999 Active Member
    4,610Coins
    awesome - nice neat simple design
    is it 12v / 24v inside ?
  8. titomaky
    titomaky Member Gold Contributor
    72Coins
    Motion platform
    all this is fine, but I ask if this will not curl the curl?
    todo esto esta muy bien, pero pregunto yo si esto no sera rizar el rizo?
  9. SeatTime
    Newcastle Australia
    25,654Coins
    It uses big RC servos.
  10. SeatTime
    Newcastle Australia
    25,654Coins
    Unfortunately, I don't understand the question. Obviously lost in translation.
  11. PetroVitallini
    PetroVitallini New Member Gold Contributor
    Norway
    427Coins
    Hello Seattime!
    Those look very responsive and well made! What kind of force does these provide? I vaguely remember you wrote in another thread that you have had experience with cars on racetracks if I'm not mistaken. How would you say the harness tensioners compare?
  12. SeatTime
    Newcastle Australia
    25,654Coins
    These do a good job and I used a similar system in my sim for quite a long time. My son said he was getting sore shoulders when testing them recently (he is 22) - so a reasonable amount of force, but I would be lying if I said they realistically mimicked the forces felt in a real race car. In my own sim I now use high Powered Ballscrew Actuators to drive my G-System and a vest/belt combination that better distributes the required loads and it feels very close to what you would feel on the track (In a F1 car, it can actually take you breath away :eek:), but unfortunately it is just too complex/heavy/expensive to ever think about commercializing and I would also be concerned about the legal issues with possibly injuring someone. It really came down to performance,cost and complexity. I've had a few people test them and they liked them, so I'm happy to sell them :).
  13. SeatTime
    Newcastle Australia
    25,654Coins
    Not easy to show a pressure system working on a video, but hopefully this video helps.
    • Like Like x 5
  14. AussieSim
    AussieSim Member
    Australia
    1,219Coins
    @SeatTime your system uses a roller, that sits below the driver's shoulder height, where the seatbelt acutely changes angle downwards.
    On the other hand, the JCL whole rig surge platform run the seatbelts backwards and slightly upwards, above the driver's shoulder height, before making a 90 degree bend vertically.
    Vesaro equally run the belts behind the seat at a non vertical angle for their seatbelt tensioner
    http://www.vesaro.com/blog/
    Have you experimented with the belt past the roller running at a 45 or 90 degree angle from the vertical, and did it make any difference ?
    Intuitively the JCL would be squezing the driver backwards into the seat (surge), whereas a vertical belt orientation would simulate heave ?
    There is no movement of the driver's shoulder girdle in their video.
    Perhaps the roller bracket could have a low and a high mounting point depending on where the driver's shoulders are in relation to the seat's shoulder harness holes ? Or 2 rollers ?
    Something like this
    https://scontent-icn1-1.xx.fbcdn.ne...=e05eeb460e8dba4d12444b7bf46f7a1e&oe=5B97067D
  15. SeatTime
    Newcastle Australia
    25,654Coins
    Good question :thumbs. As in the real world the only angle that really matters is the finally one, were it leaves the roller and heads for your shoulders. This very much depends on how well you fit your chosen seat, I can supply a larger roller which sits higher if your harness through hole is suitable to support this. The seat I used for the Demo video has the Harness holes slightly below most adults shoulders and no-one has had an issue with it so far. As detailed above, this system is not meant to compete with the big motors used on the Vesaro, or even my own sim. FI . Once you pump up the pressure to something realistic, as I have done in my own sim, then even the Vesaro system when driving just the two top belts just does not cut it as the pressures over the body start to feel very unrealistic/unbalanced), it's why I went to a multi-point vest system. Unfortunately all this realism comes at way more money and complexity :(.
  16. SeatTime
    Newcastle Australia
    25,654Coins
    At the request of a friend who tried out the system , fitted the Harness Tensioner to an office chair with just Velcro and a cheap custom harness that I made up. Works great for what it is, add a Buttkicker and your there :).
    If anyone is ever interested in a setup like this, I could look at supplying a package for sale.
  17. SeatTime
    Newcastle Australia
    25,654Coins
    I have updated the rollers to carbon fibre. Very strong and half the weight of the old ones. Never had a issue with the old ones on my rig, but just to be sure and I think it is worth the effort/cost. All the current orders will go out with these.
    • Like Like x 6
  18. SeatTime
    Newcastle Australia
    25,654Coins
    Been busy putting together orders. Slowed down some waiting for parts - but that is to be expected when you build mainly to order. Hang in there guys :). For customers info have pulled a few back down to incorporate some updates, as I'm delayed by the delivery of power supplies anyway.
  19. SeatTime
    Newcastle Australia
    25,654Coins
    Have updated the harness through hole clip to a adjustable one, which should fit most race seats.
  20. SeatTime
    Newcastle Australia
    25,654Coins
    To answer some questions, below is a video to demonstrate the noise levels out of the Harness Tensioner Servo Box while in operation. Note: This is worse case using Surge and Sway, so if you just used it for braking/surge only, it would be less fidgety and therefore quieter. First part of the video is just the tensioner in operation with background noise - in the second part I introduce typical noise from a set of headphones (what most people would also have running). You can also hear a truck drive by my house in a part of the video :).
    If you wanted it really quite, You could easily place the servo box into another wooden acoustic box - and just run the cables out through small holes in the side.
