Hall Effect Sensor
Discussion in 'Motor actuators and drivers' started by lcturkey, Aug 24, 2016.
  1. lcturkey
    lcturkey Member
    163Coins
    Hi to all,
    Anyone using hall effect sensor as 10k potans ? I did a diy hall effect potans but when I test axis and slide it right or left it works but it doesnt stop at %100 and continue to turn. When I center the slider the motor stops
    do you know what the problem is ? Pot looks like that I am using Allegro A3503 Ratiometric sensor
  2. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    16,116Coins
    Sounds like POT is going in opposite direction to motor. Try swapping the two wires to the motor so it goes in reverse direction.
    EDIT: Also if you are truning the POT by hand the motor will not stop... the POT needs to be mechanically connected to the motor to provide the closed loop position feedback.
  3. lcturkey
    lcturkey Member
    163Coins
    pots are connected to the motor. I also swapped wires but nothing changed still same
