Gtx 1080 query allready purchased
Discussion in 'Electronic and hardware generally' started by crammy, Jun 30, 2016.
  1. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    Hi all
    I got my new card today. I have gone to plug it in but I seem to be a connector missing in the pc. I wanted to get my right set up and running on triples until I have tested or purchased a rift but no luck.
    It's the eight pin one. The 6 pin is there. Is this a case of having to get a new power supply or is it a connection from the board so would need one of them instead. The instructions just say plug in connectors but don't say what they are
    Cheers all
    Jay
  2. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    It's a gtx 1080 msi gaming x if that makes a difference
  3. Ville Pesonen
    Ville Pesonen Active Member
    863Coins
  4. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    Hi mate. It doesnt have anywher to plug cables. The pc is only a year old but i think the psu is a bit old skool. All the cables are pre-installed. Been looking into it on line and found some corsair power supplies so will go and get one of those providing they come with cables
  5. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    Just bought an evga 750 gold modular with the leads so will pick it up in the morning.
  6. Nick Moxley
    17,057Coins
    Problem solved. :)
  7. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    next problem. i think i may need a new tower now as i didn't think to check the size of the psu but its a lot bigger than what is in there now. will check when i get home if it fits.
    What a donut. might as well build a new pc lol
  8. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    Im good i think. they listed the dimensions wrong on the website. They said it was 210x315mm which is the size of the packaging
  9. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    Well how's my luck. Played about with the pc and put the new psu in. I went to plug the card in and the case isn't wide enough to get past the lip on the case. New tower it is then
