Grid Autosport Plugin Request
Discussion in 'SimTools Plugins' started by Mif, Jun 24, 2014.
  1. Mif
    Mif Member
    Seattle, WA USA
    - 8Coins
    2DOF, SCN5
    Well we now have the new Grid Autosport released. I love Grid 2 and the Dirt series on my motion sim, and I would love to add Grid Autosport to it as well. I assume it should be similar to the other codemasters titles.
    Is there a chance at looking into this?
    Thanks!
    Chris
  2. eaorobbie
    20,468Coins
    We hope so too, mmm do you have the game ?
    If yes what is the process name it uses (Game exe file)
    and where is the hardwaresetting file located , with those two bits of info , I can quickly add the plugin for all.
  3. Mif
    Mif Member
    Seattle, WA USA
    - 8Coins
    2DOF, SCN5
    Sure thing. Let me get it installed and I will get this info for you ASAP!
  4. Mif
    Mif Member
    Seattle, WA USA
    - 8Coins
    2DOF, SCN5
    Looks like it is putting the config files right where you would expect: C:\Users\USERNAME\Documents\My Games\GRID Autosport\hardwaresettings\hardware_settings_config.xml
    EXE Name that runs is GRIDAutosport_avx.exe and GRIDAutosport.exe
    I have attached the renamed XML as well in case you need/want it.
    Let me know if you need anything else!
  5. eaorobbie
    20,468Coins
    Here is the test plugin, please test and tune in the Min and Max Values in the Tuning Centre. Then if you can provide a copy of your min and max values I can add this to the plugin to make it a base. Thank you, BTW have fun.
    P.S once we have it sorted I will remove the plugin from here and post it in our resource section.
    Sorry admin would like it tested first then I will move it, please leave it where it is till tested, as I don't want resources in the section that are bad.
    Sorry plugin removed , now just waiting for report back from testers, thanks, if all ok I will upload the plugin to the resource section, Thanks for testing guys.
  6. bsft
    its been 15 hrs since game release.....what took so long....
    :p
    • Funny Funny x 6
  7. Mif
    Mif Member
    Seattle, WA USA
    - 8Coins
    2DOF, SCN5
    Good Deal! I will try to give this a try tonight on my sim :)
  8. BlazinH
    16,656Coins
    I looks like Grid Autosport is worth trying out since they got some common sense again and put cockpit view back in! :)
  9. Mif
    Mif Member
    Seattle, WA USA
    - 8Coins
    2DOF, SCN5
    Just finished testing it. All looks good, but it tries to point to Grid 2's folder for the plugin install. Changed that up and it patches and works like a dream! Really decent feedback as well. Great Job!
  10. james wheeler
    james wheeler Active Member
    - 64Coins
    I really like that there is essentially 2 cockpit views. A close and far and how they did away with the steering wheel. We all have wheels already. No more misaligned double vision
  11. eaorobbie
    20,468Coins
    Opps my fault in a rush to post and have it tested, my bad, fixed and will post it into the resource section ,
    Again @Mif thanks for testing.
  12. eaorobbie
    20,468Coins
    • Like Like x 5
  13. james wheeler
    - 64Coins
    "Woop. There it is"
  14. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    16,158Coins
    I can't get the game manager to recognise the game starting? No errors when installing plugin, and patching went fine - hardware settings file seems to be updated OK.
    The process in Task Manager seems to be the same as mentioned above...
    Running Windows 8.1
    Any suggestions what to check?
  15. value1
    14,977Coins
    Sorry, please try this one.
  16. RufusDufus
    Adelaide Australia
    16,158Coins
    That seems to have fixed the problem. Thanks! :grin
