value1
GP Bikes Plugin 2.0.1.12
SimTools game plugin for GP Bikes
  1. value1
    14,225Coins
    GP Bikes Plugin - SimTools game plugin for GP Bikes
  2. bsft
    Bike plugin, well done.
  3. value1
    14,225Coins
    GP Bikes beta4b is available btw.
    Piboso is also working on a MX Bikes version!
  4. Gelatin
    Gelatin Active Member
    Hungary
    - 376Coins
    3DOF, SCN5
    Nice! Thx for that
    153,565Coins
    +11,144 / 57 / -2
  6. Demitsuri
    Demitsuri New Member
    Moscow Russia
    244Coins
    Hello! Did you know, is it work with 7b version?
  7. BlazinH
    16,686Coins
    Yes, it works.
  8. Demitsuri
    Moscow Russia
    244Coins
    Hello!
    I try it today with my scetch up model, but it is didnt work,
    I think problem can be in model, and double checked it in LFS - Everything works fine.
    When i'm exit from Gp-bikes, i have error with next text:
    System.NullReferenceException: Ссылка на объект не указывает на экземпляр объекта.
    в GPBikes_Plugin.Plugin.ShutDownCommands()
    в SimTools_GameManager.Mod_Lib.GameStoped()
    в SimTools_GameManager.frmMain.tmr_IsGameRunning_Tick(Object sender, EventArgs e)
    в System.Windows.Forms.Timer.OnTick(EventArgs e)
    в System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
    в System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    Please, help me.
    Already thank you.
  9. Demitsuri
    Moscow Russia
    244Coins
    Also, im double checked on MX-Bikes, and everything goes ok!
    153,565Coins
    +11,144 / 57 / -2
    Try unpatching, restarting Game Manager as Admin and then repatching.
    If you have any Startuo or Shutdown options set in the SimTools interface section then delete them.
  11. Demitsuri
    Moscow Russia
    244Coins
    Tryed, didnt help me unfortunatly. =(
  12. BlazinH
    16,686Coins
    Sorry, my bad!! I installed this game and the simtools plugin last November to give it a try. Game manager connected to the game engine when the game started. However, next I attempted to get the game working with Nvidia’s 3dVision but to no avail. Without 3d I don’t play so that was the end of my testing.
    So I just fired it up again to verify the plugin and my previous statement and you are right, it doesn’t work right. When it connects to the game engine, it kills the game dash. Also there are no numbers in the tuning center. When I stop the game I get the same crash data you do (less the Russian). Sorry for misleading you due to my poor recollection of the situation!
  13. luky_90
    luky_90 Member
    276Coins
    This morning I downloaded the game too, I connected everything to the evidence, when I open game engine the program is locked and says that receives signals from the game but if I try to make a virtual axis output test does not move anything, just close the game I get an identical message to the user @Demitsuri
  14. value1
    14,225Coins
    The plugin needs an update. Apparently the interface has been changed and is no longer compatible with the version of the plugin.
  15. luky_90
    luky_90 Member
    276Coins
    I downloaded the plugin to see the movements of the game because seeing a video of a motion simulator I had come up with an idea but I can not do anything because it seems to be the only bike game on the site.
  16. BlazinH
    16,686Coins
  17. luky_90
    luky_90 Member
    276Coins
    I'm interested to see the movement in the fold of the bike because seeing this video
    I was trying to understand how it works, I thought to two engines arranged under the central one in front of another, then connected together with a structure attached to the bike by the roll effect fold the motorcycle, and with an engine to develop inside the pitch effect.
  18. value1
    14,225Coins
  19. PiaMan
    PiaMan Active Member
    Saskatchewan, CANADA
    607Coins
    3DOF, DC motor, SCN5, Arduino
    launching game manager as admin allowed me to do the patch. Thanks for the info noorbeast
  20. spyderwash
    spyderwash genesy sim
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    GP Bikes Beta 9c new version no longer compatible plugin will be updated or expects simtools again?
