Question Gearchange - too much movement
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Arazok, May 8, 2019.
  1. Arazok
    Arazok Member
    Computer scientist
    783Coins
    I am satsified with my 2DOF rig, now running with sabertooth 2x32.
    But a gear change (e.g. in project cars 2) is very hard, as the surge value is changing very quick.
    This is not feeling like in a real car.
    So, any idea how to smoothen the gear change in terms of rig movement ?
    Is the only chance to change the surge values inside tuning center (higher max value, lower min value) ?
    cheers,
    Arazok
    154,472Coins
    +11,183 / 57 / -2
    You will likely need to try a higher value in the Tuning Center to soften surge.
  3. Arazok
    Arazok Member
    Computer scientist
    783Coins
    Yes, that's what I thought. Higher values for max, Lower values (or higher negative values) for min
  4. kparkin
    kparkin Member
    United Kingdom
    236Coins
    4DOF
    Doesn't this reduce the amount of movement though?
    154,472Coins
    +11,183 / 57 / -2
    Increasing the TC value will give a slower response over a greater movement range.
  6. kparkin
    kparkin Member
    United Kingdom
    236Coins
    4DOF
    Of course, I had it backwards.
    Thanks.
  7. Arazok
    Arazok Member
    Computer scientist
    783Coins
    That's the reason why I was asking.
    Is there anything to change the behaviour of the rig in terms of a gear change without touching/changing the movement of the rig with regards to acceleartion/deceleration or surge.
    So to smoothen only the gear change, not the rest....
    154,472Coins
    +11,183 / 57 / -2
    Please post pictures of all of your settings and if possible a video that shows the rig movement and game screen at the same time.
    Have you manually offset the Max/Min values, if so try reducing our eliminating the difference in values.
  9. Arazok
    Arazok Member
    Computer scientist
    783Coins
    Video would be feasible earliest on weekend.
    But now you are irritating me, saying that I have to reduce the difference in min/max values.
    I thought to smoothen the movement, you have to increase the max value and decrease the min value (larger range), but this would increase the differences in values...
    154,472Coins
    +11,183 / 57 / -2
    I am not suggesting you reduce the values, what I am saying is that many members manually set a different Max and Min value to amplify gear change effects. If you had done that then what I was suggesting is that you pick the higher value and use it for both Max and Min values.
