game manager exception
Discussion in 'SimTools DIY Version' started by bruce stephen, Jul 15, 2015.
  1. bruce stephen
    general contractor
    michigan
    9,114Coins
    so im iracing the sim goes goofy. i back out of the race restart and pow no more simtools? i get the following exception:
    ************* Exception Text **************
    System.NullReferenceException: Object reference not set to an instance of an object.
    at SimTools_GameManager.Mod_GameProfileLoader.GameProfileChanged()
    at SimTools_GameManager.frmMain.cb_GameSelection_SelectedIndexChanged(Object sender, EventArgs e)
    at System.Windows.Forms.ComboBox.OnSelectedIndexChanged(EventArgs e)
    at System.Windows.Forms.ComboBox.set_SelectedIndex(Int32 value)
    at SimTools_GameManager.frmMain.frmMain_Load(Object sender, EventArgs e)
    at System.EventHandler.Invoke(Object sender, EventArgs e)
    at System.Windows.Forms.Form.OnLoad(EventArgs e)
    at System.Windows.Forms.Form.OnCreateControl()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.Control.CreateControl()
    at System.Windows.Forms.Control.WmShowWindow(Message& m)
    at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
    at System.Windows.Forms.ContainerControl.WndProc(Message& m)
    at System.Windows.Forms.Form.WmShowWindow(Message& m)
    at System.Windows.Forms.Form.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.0.30319.34209 built by: FX452RTMGDR
    Assembly Version: 0.1.3.0
    Win32 Version: 0.1.3.0
    CodeBase: file:///E:/Program%20Files%20(x86)/SimTools/SimTools_GameManager.exe
    Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 12.0.51209.34209 built by: FX452RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
    Win32 Version: 4.0.30319.34238 built by: FX452RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    Win32 Version: 4.0.30319.34251 built by: FX452RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Runtime.Remoting
    Win32 Version: 4.0.30319.34245 built by: FX452RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    Win32 Version: 4.0.30319.34234 built by: FX452RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    PluginAPI
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///E:/Program%20Files%20(x86)/SimTools/PluginAPI.DLL
    ok so reinstall? we'll see.
  2. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,796Coins
    No sure, as you use Arduino, but I see this behaviour if my JRKs lose the USB port, in other words they get over worked and fall over.
    You can test this by unplugging the USB as you play, and Simtools will crash.
    If so, you may need to check your Ards / MM's are not giving up the ghost mid-play.
  3. bruce stephen
    general contractor
    michigan
    9,114Coins
    hmm clean install it works again but lost all my settings. is ok i like to tweak settings. who knows what i did. seems ok now.
  4. bruce stephen
    general contractor
    michigan
    9,114Coins
    @Archie what do u mean giving up the ghost?
    150,644Coins
    +11,018 / 55 / -2
  6. Archie
    Wollongong, NSW, AU
    3,796Coins
    Sorry @bruce stephen - It's an English saying. For when something stops working - "It gives up the ghost"
  7. bruce stephen
    general contractor
    michigan
    9,114Coins
    Ok @Archie makes sense. Ty @noorbeast good to know, I spent a couple hours setting it back up.
