Question Game Engine Tool stops working.
Discussion in 'SimTools Pro & Entertainment Version' started by Bastiuscha, Jan 6, 2019.
  1. Bastiuscha
    Bastiuscha Active Member
    750Coins
    Hey mates,
    since today, my simtools "Game Engine" stop working, after a few seconds driving. Sometimes, after 5 seconds, somtimes, after one minute. But not longer than maybe 90 seconds. I did not change anything. I don't have a error message, but somtimes i can hear the windows usb sound. If after that, i restart the tool, it works again, for a few seconds. I don't know, where ist the problem. The Game Manager and Game Dash are still working in this time!
    150,686Coins
    +11,018 / 55 / -2
    That could be a USB disconnect, have you tried different USB cables and USB ports?
    Also isolate each interface one at a time to see if you can narrow down the culprit.
  3. Bastiuscha
    750Coins
    I've been thinking about usb, too. But now, i believe i found the problem. Because i was sick, a long time i did not driving. I forgot, that i install these baby's, to prevent the current from flowing back to the power supply unit.
    https://www.ebay.de/itm/1PC-MDQ-100A-Amp-1600V-Volt-Single-1-Phase-Diode-Metal-Case-Bridge-Rectifier-AB/153164088784?_trkparms=aid=555018&algo=PL.SIM&ao=2&asc=20180306143914&meid=803b8a9b3e674cfe986266e5ef40711f&pid=100935&rk=1&rkt=7&sd=253653876568&itm=153164088784&_trksid=p2056116.c100935.m2460
    I don't know, what i could do wrong. I asked a friend with electronic skills. He said, i connected the calbe good. Ok...if that was really the problem, (i seems to be) i know now where I need to investigate further.
    Thanks for your help!
    150,686Coins
    +11,018 / 55 / -2
    Pretty much anything running Win 7 or latter. If a PC can run the games you want, at the quality settings you want, then it should not really have much issue also running SimTools.
