Forza Horizon 5
Discussion in 'SimTools Plugins' started by DTHCR, Nov 6, 2021.
  1. DTHCR
    DTHCR New Member
    Queensland, Australia
    336Coins
    Here is a plugin for forza horizon 5 for console manual start, it may work on pc.
    it has a little issue on some of pause screens where the plugin still receives game data, unsure if its the plugin or the game still sending data, all i did with this is decompile the orignal horizon 4 plugin and change name, credit should go to @value1 and @yobuddy for the original plugin.
    its not the best, but it works of for me.
    • Like Like x 5
  2. ALXXX
    ALXXX 2Dof Motion in progress Gold Contributor
    Stuttgart
    7Coins
    Fantastic ! Thanks very much. I'll try and hope it works. Thumbs up ! I use the xbox series x. In Forza Horiozon 4, telemetry for xbx is broken.
  3. Magnum95
    Magnum95 New Member
    23Coins
    3DOF, SCN6
    I tried it on PC but does not work.
    Let's be patient.
    Thanks anyway for sharing.
  4. linkostex
    linkostex New Member
    - 6Coins
    No, I can confirm it's working on PC.
    I play with this plugin every days with the Microsoft store version of the game. Many thanks for this plugin.
    But i'm agree that it's not perfect : Manual launch is not the best. And there's some minors strange moves.
  5. Magnum95
    Magnum95 New Member
    23Coins
    3DOF, SCN6
    May be I missed this "manual launch".
    How do you proceed exactly?
    So far, I just threw the plugin as usual, patched it and nothing more.
  6. linkostex
    - 6Coins
    Open the simtools Game Manager and click the "play " button beside the name on the game
  7. Magnum95
    Magnum95 New Member
    23Coins
    3DOF, SCN6
    Thank you for the tip. ;)
  8. linkostex
    - 6Coins
    you're welcome :)
  9. Magnum95
    Magnum95 New Member
    23Coins
    3DOF, SCN6
    No moves at all.:(
    Let's wait for upcoming udpate then.
  10. linkostex
    - 6Coins
    Have you activate the data transmission directly in the game ?(it's on the gameplay page on parameters)
    If you have simtools on the same PC you must put the IP : 127.0.0.1 and 4123 for the port
    it should work
  11. Magnum95
    Magnum95 New Member
    23Coins
    3DOF, SCN6
    It works !
    My son thanks you so much !
    hug:
  12. linkostex
    - 6Coins
  13. paulopsx2
    paulopsx2 Active Member
    brasil
    616Coins
    works for you? HOW DO YOU PUT this port and ip exactly? i try 127001 and 4122 and dont works
  14. paulopsx2
    brasil
    616Coins
    ok, it works. but not with my lopback 127. i just put my original ip. tks
  15. Mamourou mami
    Mamourou mami New Member
    - 179Coins
    Arduino, 4DOF
    your advise my help
  16. noorbeast
    144,950Coins
    +10,770 / 52 / -2
    Can you please be more specific about what you are looking for.
  17. ivan jack
    ivan jack Member
    412Coins
    I can confirm that the manual start plugin works awesome on PC after reading max min values. Both simtools and simhub work .
  18. FeifeiHooray
    FeifeiHooray New Member
    China
    50Coins
    Hi, I met a problem after entering the game, it moves, but randomly and violently, almost threw me out.
    I have turned on data output with 127.0.0.1 : 4123, and pressed the play button in Game Manager ( although it cannot open the game directly).
    The simulator should be fine, it works well for ACC.
    So are there any other points I missed? I need your guys help! Thanks!
  19. noorbeast
    144,950Coins
    +10,770 / 52 / -2
    Posting pictures of all of your settings will make it easier for others to offer suggestions. Likely your motion profile needs refining.
    Grab a copy of the SimTools manual and keep it handy for reference: https://www.xsimulator.net/community/faq/rtfm-start-with-the-official-simtools-documentation.117/
    Then check out the Profile Tuning Tips in the FAQs: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    Make sure you capture the Max/Min values in the Tuning Center and then tweak from there.
  20. FeifeiHooray
    China
    50Coins
    Hi noorbeast, appreciate your reply, here is the setting. Should I make the Max/Min values smaller integer?
