For Raceray: some iRacing Pros and Cons
Discussion in 'Off Topic - All other stuff here' started by Leedo, Jun 26, 2009.
  1. Leedo
    Leedo New Member
    Illinois, United States
    This is certainly not a complete list, just some thoughts/impressions.
    My bias: I like iRacing very much, however I do understand why it's not everyone's cup of tea. Also, it seems to be the perfect sim for motion, because of the detailed tracks.
    Some Pros:
    Tracks:
    I've never driven on a real track before, but iRacing's tracks have bumps, camber changes etc., that definitely affect the car
    Generally very clean, courteous racers--also very competitive
    With a FF wheel you can feel just about every bump, camber change etc.
    Physics:
    Don't know since I don't race for real, but for the virtual car I drive the most (Star Mazda), they feel great
    Lots of helpful tips, setups, replays and discussion on the forums
    Safety Rating:
    You need to not wreck too much to move up to faster cars, and it won't happen overnight but it's certainly achievable. It's a 'no-fault' system, and you do sometimes get penalized for someone else's mistake (and sometimes others get penalized for your mistake!).
    The developers seem to listen to feedback from users
    Every 12 weeks there's an update and it takes about 3 clicks to download and install it
    You can practice with other racers on open practice servers
    Some Cons:
    Tire Model is a work in progress. Not sure on this, but my guess is that most people make setups based on handling as much or more than tire temps.
    No top level open-wheeler:
    Currently the fastest open-wheel car is the Star Mazda. No news currently on a modern F1 car--there is the Lotus 79 F1 rumored to be coming out fairly soon.
    No tire smoke from other cars
    No leagues--this is planned but I don't think there's a firm date (not sure)
    More expensive than other sims
    No towing/damage repair
    Not enough non-US content:
    Currently lots of US cars and tracks, some non-US stuff coming
    Camera positions are hardwired, and while you can 'pause' a camera position as it moves, you can't move it anywhere you want
    No sector times
    Could be pro or con:
    Races at scheduled times:
    Each series has races at specific times, more often for lower level series and less often for higher level series
    Good threads to get more info (pro and con) and probably answer any question:
    http://forum.racesimcentral.com/showthread.php?t=334237
    http://forum.racesimcentral.com/showthread.php?t=334216
    iRacing Rumors--this is kinda fun to read:
    http://www.iracingworld.com/_iRacing-Wh ... 57752.html
  2. RaceRay
    23,875Coins
    Hi Leedo,
    thank you very much for the summary :) I think the pros are very comparable to rFactor,. Most of your cons do not exist in rFactor. Also the render engine looks very similar.
    Maybe you already know that video? http://www.virtualr.net/iracing-vs-rfac ... omparison/
    I am actually very terse, no time to write all i think...but i thank you very much for your efforts. :cheers:
    regards
    René
  3. Ringorumble
    Ringorumble Active Member
    190Coins
    Maybe take a look at the little and big bumps which is more interesting that if the corner is the same in both, especially for motion sim guys. Since GPS is cheap an Bobs track builder can import them its not that hard to get a real accurate track into rfactor with some effort.
    Anyway no bashing or so, but i only went 3 times back to rfactor for league races, and it felt dead. I was a Rfactor Fanboy for sure.
  4. Leedo
    Leedo New Member
    You're welcome--hope the pros/cons were helpful. :cheers:
