FlyPT Mover 3.5.8
  1. pmvcda
    pmvcda aka FlyPT
    Portugal
    16,036Coins
    That's a bug, solved for the next build.
    I still need to solve some problems before release. taking to long, but closer.
  2. bruno1210
    bruno1210 schumi06
    103Coins
    Hello, I am looking for a preset for f1 2021 a .mover file I would just like the sway and surge thank you.
  3. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,900Coins
    DC motor, 6DOF
    The easiest way is to use a combination of EMALP (smoothing) and EMAHP (washout).
    Just map longitudinal accel on your surge axis and lateral accel on your sway axis and use EMA values to fit your needs
  4. SeatTime
    Tried to get VTOL VR working with motion again and it seems to not work with the latest version of FlyPTmover. Can see the data in the source so it is available and the Pose sliders gray out, but nothing shown in the POSE: FROM MOTION. Maybe something that can be looked at in the future.
  5. Roller2525
    Roller2525 Member
    220Coins
    I am wanting to create an effect like in this video at 11:58. Basically a noise effect or short sharp wing rock when a bomb is released. I was able to replicate it somewhat in Simfeedback by extracting weapon count data through the lua. Would this be possible with Mover?
  6. Rainman@121
    Rainman@121 New Member Gold Contributor
    - 29Coins
    AC motor, 6DOF
    Give this a try.
    • DCS.zip
      File size:
      4.2 KB
      472
  7. deadlymanager
    deadlymanager Member
    12Coins
    Best setting for helicopters not for aircrafts. Tested on 6DOF rotating hexapod by professional pilots.
  8. Roller2525
    Roller2525 Member
    220Coins
    Thanks @deadlymanager! I will give it a go.
    @pmvcda do you think we could add weapons deployment telemetry for DCS? It would add awesome immersion. Station number and weapon type would be good so that different effects could be added for different weight weapons. Heavier bombs dropping from the wing would be felt more than lighter bombs. I would assume the data would be taken from the following?
    LoGetPayloadInfo() -- return weapon stations
    result_of_LoGetPayloadInfo
    CurrentStation = , -- number of current station (0 if no station selected)
    Stations = {},-- table of stations
    Cannon =
    shells -- current shells count
    station
    container = true/false , -- is station container
    weapon = {level1,level2,level3,level4} , -- world database classification of weapon
    count = ,
    Could this be added simply enough to the DCS lua hook file?
  9. pmvcda
    pmvcda aka FlyPT
    Portugal
    16,036Coins
    I can take a look. Still need to review the DCS for the new release, and will try to do it.
    The effect on the plane should be already on the physics, but it's a good way to increase the effect and avoid the masking generated by the motion cue alghorithm on the physics side.
  10. Roller2525
    Roller2525 Member
    220Coins
    Yes, the physics are there. But as you said, it is masked by smoothing filters. There is also wing flex telemetry that could be used, but ideally having the effect linked to weapon release only would be the perfect situation.
    Thank you for such great software by the way!
  11. BrassEm
    BrassEm G-Seat + SFX100 Builder Gold Contributor
    NE of YMML
    1,102Coins
    DC motor, AC motor, 4DOF
    @pmvcda Hopefully a quick question for you. I don't want to distract. Before I go down the rabbit hole, I have two motion rigs. Each one controlled by a Thanos AMC-AASD15. One an SFX-100, the other a hybrid g-Seat, both with 5 motors. The additional axis being Surge and Back Scrub respectively, which must be scaled independently. They must all feed from the exact same source.
    Does your software support two output modules concurrently in the one instance? If not, is FlyPT Mover able to run multiple instances? (Distributed TCP/UDP which it looks like you have accommodated.)
  12. pmvcda
    pmvcda aka FlyPT
    Portugal
    16,036Coins
    No multiple instances, but you can add the outputs you want.
    I use two serial outputs in my rig. I have 6 actuators, with two ESP32 to control them.
    The limit is processing speed.
    The way it's done, you could have two rigs working, each from it's own source with all data idependent from each one.
    You just need to be sure that they don't use the same UDP port (in the sources or outputs) and the same serial port.
  13. wingert
    wingert Active Member
    744Coins
    4DOF
    Have some question about the pose suspension.
    What are the meaning of wheel base and track values in suspension pose ? Is that the distance of the actuator or is that from car in game ?
    If its the actuator how does it affects the L1 L2 values in rig module ?
  14. pmvcda
    pmvcda aka FlyPT
    Portugal
    16,036Coins
    L1 and L2 are needed, to make sure the roll or pitch sent to the rig is represented by the rig.
    What we control is the travel of the actuators, so the only way to make sure we get 10º pitch is knowing the distance between actuators.
    In the suspension it's the same, but on the source side.
    We get suspension travel and convert it to roll, pitch and heave.
    The same amount of suspension travel produces different pitch and roll depending on the distance of the wheels.
    The values by default are generic and I think they work ok for most of the cars.
    So you have the suspension pose that might calculate 10º pitch from the suspension travel and the wheels distance. Now we want the rig to be 10º, we calculate the actuators to achieve it for the L distance.
    Edit:
    For aircrafts, Mover distributes the travel on the 4 wheels. An aircraft might have 3 wheels, one at the front or rear..
    But we can change the effect also, by playing with the wheels distance.
    But it's not so direct as cars.
    In the end aircraft effect is just on the ground, maybe less than 1% of all the motion we use.
  15. wingert
    744Coins
    4DOF
    Thanks for your answer.
    Am I right I can let the track and wheelbase date in suspension as default or for fidelity that from car manufacturer ?
    Another point is about basic concept of race car platform mover.
    Am I right, it is possible to use the suspension position data with reference to road surface,
    or alternative vertical acc. and pitch and roll position with reference to absolute ground like sea level.
    The first is more precise as no dimension error exist, matched for static monitors, therefore a litte gravity error on hills, the second seems more useful in case of low speed application, like off-road racing because of missing dynamical force in a static sim like centrifugal ?
  16. pmvcda
    pmvcda aka FlyPT
    Portugal
    16,036Coins
    Default is enough, but for precision, I allow the user to change it.
    The motion generated by the suspension is not what you feel in the chassis.
    Example: you are making a jump in the air and the car suspension extends, but the chassis motion is not related.
    I use the suspension module to get some rumble, and the pose from motion for car chassis info.
    Normally, I use linear accelerations and rotation positions.
    If we are speaking of slow cars in all terrain, like mudrunner (next build) I don't filter the rotations.
    Remember you can use more than one pose, each with different filters.
  17. Ronan Design
    Toronto, Canada
    1,716Coins
    Hi, I can't connect to the hook for Star Wars Squadrons. Is there update data for the memory hook anywhere, like in Elite Dangerous?
  18. wingert
    744Coins
    4DOF
    Another question about suspension.
    I have realize, if I only alter one suspension value for one strut (wheel) manually, the variation effects all four actuators in Rig module, creating some pitch and roll. Deactivate pitch and roll (Rig modul pos limits zero) it moves all four actuators with same amount.
    I think having a direct mapping for each actuator that represent native roll and pitch from game would be nice, so must only tune some gain. (Different geometrie and driver position between real and rig)
    As your program of modular concept is so brilliant, I create such feature with four sets of pose from DOF value (filter mul 1000, DOF heave) and 1 DOF of single linear actuator (park position -100mm). Principle it works fine for newer original cars in RF2 but with older and mods it request some uncomfortable matching in various moduls for park position and gain.
    Is it posible to do that in a much simple way or getting a direct feature for 4DOF and suspension ?
  19. wingert
    744Coins
    4DOF
    I admit that direct output makes only sense, if having the same track and wheelbase or ratio between real and rig, otherwise I get some distortion ?
  20. pmvcda
    pmvcda aka FlyPT
    Portugal
    16,036Coins
    yes
    Like you already found, you can act directlly on ech actuator and send it the suspension position.
    But then the distance is not right.
    What you can do is apply some scale to each actuator to adjust for the distance, but the relation longitudinal/lateral will be wrong also.
    Is there a reason you need the perfect match?
    I could add some solution...
    Been to busy, have the new build almost done, but can' seat near the pc to work in Mover for the last weeks...
