First Build: SFX-100 - Total N00b
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by raphpunk, Oct 14, 2020.
  1. raphpunk
    raphpunk New Member
    17Coins
    Hey all,
    Been researching for a couple of months now and I'm looking to build the SFX-100 I believe. I have found some parts lists but as I am not the most technical and these are a bit dated, I was wondering if anyone has found a slightly cheaper solution for the motors for the actuator build.
    Any help is greatly appreciated.
  2. Thanos
    Electronics Engineer
    United States
    2,917Coins
    This kit includes everything, even the servomotors:
    https://eracing-lab.com/collections/diy-projects/products/diy-mega
    No need to 3D print parts or anything, just follow the instructions (ikea style) to assemble them all in just about 2-3 hours...
    Thanos
  3. Marc Engels
    Marc Engels New Member
    72Coins
    this sounds brilliant! So if I understood right, you only need this kit + the Alu Profiles and you are done??? Really???
    Do they also have some addon kit for surge and TL?
  4. Trigen
    Trigen Active Member
    2,892Coins
    Make sure you take these apart and check everything if you go for these though. There has been some concerns (but not many that i can see) raised on the quality of the parts and factory assembly. But like i said, check these thoroughly before you use them.
  5. Trigen
    2,892Coins
  6. Marc Engels
    72Coins
    Yes thanks, I was told before. I wrote with eracing lab now and it seems they changed the process and are now sending photos of the assembly process and what’s inside... no blue tape anymore...
    And tbh, I am sure they will do it better than me with my two left hands...
