Fast actuator ?
Discussion in 'Motor actuators and drivers' started by Gadget999, Nov 1, 2018.
  1. Gadget999
    11,941Coins
    Take a look at this fast actuator
    It appears it will lift 100 kg
    150,602Coins
    +11,017 / 55 / -2
    What are the full specs, do you have a link?
  3. Pit
    30,472Coins
    fast but unusable...duty cycle is 10%, 2 minutes work, 18 minutes "pause in the shooting"...
  4. Pit
    30,472Coins
  5. Gadget999
    11,941Coins
    I reckon you could use them in pairs to half the load
  6. Pit
    30,472Coins
    Sure, but duty cycle does not change at all. So what is the verdict? The best actuator you can buy is a DIY one.
  7. BlazinH
    16,651Coins
    The duty cycle is really just a manner of heat management so if you can solve that they could be used. That said I don't see a good way of cooling the motors when they're stuck in a sealed tube with other components.
  8. Pit
    30,472Coins
    Actuator = $ 200.-
    Hydrogen Cooling = $ 2'000.-
    Jokes aside, also standard motors needs cooling from time to time, my 12V motor from a winch under my seat (heave) is getting very hot, to avoid a death of heat I thrilled a lot of holes into it and added two ventilators on each side. If you know where to open the actuator (which should be difficult to know) cycle rate and durability will improve.
  9. Gadget999
    11,941Coins
    It might be possible to mod them with a better motor,
    I would be keen to see inside one to see what components are in there
  10. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    Sorry to bother, it is just I'm intrigued:p:D
    I saw you searching and asking a lot of questions for some months about all the different diy actuators and commercial ones, after all that research, don't you think it is more feasible to just copy the best of each and diy or just copy one?
    Regards
  11. Gadget999
    11,941Coins
    Yes i have been doing some research
    It appears a 3dof with gearmotors is fine for a driving sim
    For 6dof with linear actuators i think a 1kw 48v dc motor with shaft encoder and ballscrew should outperform most commercial actuators
    I am still researching stepper motors and some have good torque but are quite noisy. The precision of a stepper is not needed for an actuator of this type
  12. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,943Coins
    It might be suitable for flying. Flight sim doesn't work the motors anything like as hard, though heavy turbulence might give them a workout.
