Fanatec Wheel Speed Indicator wrong on some AC courses
Discussion in 'Assetto Corsa' started by GTexas, Jul 4, 2017.
  1. GTexas
    GTexas New Member
    Houston, TX
    475Coins
    Hi, I have the Fanatec V2.5 BMW wheel with the speed indicator in the wheel. I noted that on some courses in Assetto Corsa (eg Silverstone) the speed indication at the wheel is erratic (not matching the cockpit display) while on other courses it is working fine. The use of FanaLEDs does not make a difference.
    Any ideas?
  2. Seth2Christ
    Seth2Christ Member
    192Coins
    I think the problem has been corrected because I did not have this problem.
    Do you still have this indicator problem?
  3. GTexas
    GTexas New Member
    Houston, TX
    475Coins
    I did not check recently. I now use a HTC Vive and don't see the speed indication on the wheel anyhow.
