Falcon BMS 4.33
Discussion in 'Digital Combat Simulators (DCS)' started by sunny_hk, Mar 9, 2016.
  1. sunny_hk
    sunny_hk New Member
    250Coins
    See what simtool can do on Falcon BMS 4.33
  2. sunny_hk
    sunny_hk New Member
    250Coins
    Hi all, just wondering what simtool can do for BMS 4.33.
    I would like to make some gauge, is it possible?
    150,578Coins
    +11,017 / 55 / -2
  4. sunny_hk
    sunny_hk New Member
    250Coins
    150,578Coins
    +11,017 / 55 / -2
    Why not do a detailed post about your static sim pit and what you plan for motion.
    Check your coin count now.
  6. sunny_hk
    sunny_hk New Member
    250Coins
    Wow, Thank you so much for you help, noorbeast. Actually, I am not yet thinking of make my sim pit for motion (maybe after i changed a big home). I just want to make some gauge like RPM for my pit. I am new here, and still learning how to. is it possible to use simtools to make a gauge for Falcon BMS?
    once again, thank you very much for your gold. ^^
    150,578Coins
    +11,017 / 55 / -2
    As I mentioned earlier the Falcon BMS plugin author @value1 stated that "Additional values for instruments are feasible, yet not implemented".
    I am sure I and other members would like to know about the construction of your sim pit and particularly the switch panels. Care to share the details?
  8. Historiker
    Michigan USA
    9,208Coins
    @sunny_hk
    There are already many resources for Bms 4.33 out there. I use screen extractors for my pit such as Lightnings MFD extractor (which can do any gauge as well).
    A great resource for anything Falcon 4 simpit related is Viperpits.org. Huge amount of info there, the Falcon cockpit building community is massive.
  9. Historiker
    Michigan USA
    9,208Coins
    @sunny_hk from the Warthog controller thread I see that you already have a Viperpit so must know about Viperpits.org. If you have not found anything there then another possible alternative is checking out Symprojects.com and asking the creator for support for BMS. If you can convince him of the possible customer base (which is great) then he might write a plugin for his hardware. I have several of his products that they are very good for the price. Much cheaper than you probably spent on your ICP :) (I make plug and play ICP modules for fellow Falcon pilots).
  10. Historiker
    Michigan USA
    9,208Coins
    Sorry for the many posts but I have been doing a little more research on this today.
    There are dozens of Arduino projects for BMS gauges out there. Here is one posted on Youtube last month that looks really good:
    Here is the info about the project on Viperpits.org:
    http://www.viperpits.org/smf/index.php/topic,10209.30.html
  11. shrav
    shrav New Member
    texas
    61Coins
    Nice setup!
