F1 23 Plugin
Discussion in 'News' started by SpidiHD, Jul 24, 2023.
Tags:
  1. SpidiHD
    SpidiHD Member Gold Contributor
    178Coins
    Hello guys,
    any update on the f1 23 plugin release?
    is there any guidance on how the previous plugins were made? i would like to learn how to develop it.
    what is the difference between xsimulator.net and simtools.us?
  2. Ads Master
    Ads Master
  3. yobuddy
    46,431Coins
    Already posted for v3.
    https://simtools.us/plugin/?varname=557&color=0e97dd
    https://www.xsimulator.net/communit...in-for-simtools-v3-0-api-documentation.17019/
    This will help explain stuff buddy.
    https://www.xsimulator.net/community/threads/insights-into-simtools-and-xsimulator-partnership.9645/
    (Know that SimTools v3 has the plugin available right in the app)
    Take care,
  4. SpidiHD
    178Coins
    I'm trying to install the plugin but i have F1 2023 on Origin and not in Steam. Is this a problem?
  5. SpidiHD
    178Coins
    i think is not a problem because the sw recognize the game started but how do i configure the game? UDP or TCP? Port number? Format UDP 2021, 2022 or 2023?
  6. SpidiHD
    178Coins
    With this settings it works but i have to click the button to start the game on SimTools (probably because i am on Origin).
  7. zhai1987
    zhai1987 Member
    305Coins
    2DOF, 3DOF, AC motor
  8. yobuddy
    46,431Coins
    SimTools v2 is available, and downloadable, from both this website and simtools.us.
  9. zhai1987
    zhai1987 Member
    305Coins
    I installed this plugin F12023_V4_GamePlugin in SimTools V2 and it appears like this, can you help me?
  10. zhai1987
    zhai1987 Member
    305Coins
    System.NullReferenceException: Object reference not set to an instance of an object.
    at SimTools_GameEngine.frm_TuningCenter.LoadGameList()
    at SimTools_GameEngine.frm_GameEngine.frmMain_Load(Object sender, EventArgs e)
    at System.EventHandler.Invoke(Object sender, EventArgs e)
    at System.Windows.Forms.Form.OnLoad(EventArgs e)
    at System.Windows.Forms.Form.OnCreateControl()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.Control.CreateControl()
    at System.Windows.Forms.Control.WmShowWindow(Message& m)
    at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
    at System.Windows.Forms.Form.WmShowWindow(Message& m)
    at System.Windows.Forms.Form.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.9181.0 built by: NET481REL1LAST_C
    SimTools_GameEngine
    Assembly Version: 0.2.6.0
    Win32 Version: 0.2.6.0
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/SimTools_GameEngine.exe
    ETFgktGMYNvzVOhtEdFZFkYsRAjH
    Assembly Version: 0.0.0.0
    Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
  11. zhai1987
    zhai1987 Member
    305Coins
    What am I supposed to do?!
  12. noorbeast
    141,826Coins
    +10,614 / 52 / -2
    Just checking, did you try to install the v3 plugin in SimTools v2? If so plugins for v3 are not compatible with v2.
  13. zhai1987
    zhai1987 Member
    305Coins
    Remove the software and reinstall! Work out
  14. zhai1987
    zhai1987 Member
    305Coins
    Does F1 2023 have V2 plugins?
  15. yobuddy
    46,431Coins
    No, but SimTools v3 is a free upgrade for all v2 users, and v3 has the plugin available.
    Take care!
  16. Bartosz Kopciuch
    Bartosz Kopciuch New Member
    12Coins
    You know maybe, how I can open F1 23 in VR mode together with simtoolsvV3 ?
    Started only standard version.
