F1 2020
Discussion in 'SimTools Plugins' started by Buytaert Luc, May 22, 2020.
  1. Buytaert Luc
    Buytaert Luc New Member Gold Contributor
    Belgium
    77Coins
    Motion platform, 4DOF
    I'm looking for the F1 2020 plugin. We are testing the beta of F1 2020 and telemetry data is published on the website of Codemasters. Hopefully plugin will work also with DX12 and uses the 2020 format. Not like the F1 2019 plugin which is working only for DX11 and uses the legacy format.
    150,596Coins
    +11,017 / 55 / -2
    Plugins are not often created for Beta games, as stuff is constantly changing, so plugins tend to be created after a game is released and is stable.
    Have you considered trying the 2019 plugin to see if it works? Rename the exe if required.
  3. Buytaert Luc
    Belgium
    77Coins
    "Have you considered trying the 2019 plugin to see if it works? Rename the exe if required." I did not, because 2019 plugin is working only for DX11 and uses the legacy format.
  4. Floris-Jan Eduard Lip
    Floris-Jan Eduard Lip Build4Power Racing
    The netherlands
    - 233Coins
    4DOF
    i've tried renaming the .exe file but to no succes, the game wont start with the exe filename changed
  5. Daguru
    Kitchen installer
    Wales uk
    454Coins
    Motion platform
    If you can patch it with the 2019 plugin, try making a copy of the CMD prompt on to your desktop and then rename that to what ever the game .exe is called, then run that it will trick simtools to start up and think the game is running ive done this with a few games while waiting for a real plugin to be made and its worked great.
  6. bruno1210
    bruno1210 schumi06
    103Coins
    Hello, the plug-in works with the 2018 format also thanks to simhub.
