Question F1 2018 plugin
Discussion in 'Other Racing Games' started by alexdraco, Sep 4, 2018.
  1. alexdraco
    alexdraco Member
    278Coins
    Did any of you use the F1 2017 plugin for the new F1 2018 game just released?
    Is there a chance that it will work?
    Thanks.
    145,052Coins
    +10,776 / 52 / -2
    If the game pointers are different, and that is very likely, it will not work.
  3. Damien
    Damien Member
    watchmaker
    Royan
    724Coins
    2DOF, SCN6
    No, it can not work.
  4. Damien
    Damien Member
    watchmaker
    Royan
    724Coins
    2DOF, SCN6
    I have a question ...
    If I buy the game in Blueray format, can I install it on my PC and play without an internet connection ??
    or do I have to have internet to activate it ???
    I do not have internet at home, only at work.
    I already started the plugin (thanks to the tutorial Yobuddi) but I need the game to finish it ...
    French
    Justement, j'ai une question...
    Si j'achète le jeu en format Bluray, est-ce que je peux l'installer sur mon PC et jouer sans connexion internet??
    ou dois-je absolument avoir internet pour l'activer???
    Je n'ai pas internet chez moi, seulement au travail.
    J'ai déjà commencer le plugin (grâce au tuto de Yobuddi) mais il me faut le jeu pour le finir...
  5. alexdraco
    alexdraco Member
    278Coins
    I do not know, I've been using steam for a few years (platform to buy online games).
    you have to make sure if your game requires the activation of the license with internet, and even a permanent connection to play.
    In my opinion if you have the serial code on the cd or on the box it should be possible to play without internet.
  6. alexdraco
    alexdraco Member
    278Coins
    thanks but i have a question:
    who writes the plugins, are the users of the forum?
    what information do you need to have to write? (besides being able to program)
    145,052Coins
    +10,776 / 52 / -2
    It is a small and very dedicated group of members who create and maintain plugins.
    Creating plugins takes skill, practice and patients, as it can take a good deal of time, see here regarding how to create a plugin and the tools invlved: https://www.xsimulator.net/community/faq/how-to-write-a-plugin-for-simtools-api-documentation.131/
  8. alexdraco
    alexdraco Member
    278Coins
  9. SilentChill
    20,400Coins
    F1 2018 telemetry is provided by UDP and just needs the plugin updating. I would do it but I do not have the game and I am not going to buy it as I will never play it, however if anyone wants to gift it me that's fine :p
    Or you can do it yourself using this :)
    MOTION PACKET
    The motion packet gives physics data for all the cars being driven. There is additional data for the car being driven with the goal of being able to drive a motion platform setup.
    N.B. For the normalised vectors below, to convert to float values divide by 32767.0f. 16-bit signed values are used to pack the data and on the assumption that direction values are always between -1.0f and 1.0f.
    Frequency: Rate as specified in menus
    struct CarMotionData
    float m_worldPositionX; // World space X position
    float m_worldPositionY; // World space Y position
    float m_worldPositionZ; // World space Z position
    float m_worldVelocityX; // Velocity in world space X
    float m_worldVelocityY; // Velocity in world space Y
    float m_worldVelocityZ; // Velocity in world space Z
    int16 m_worldForwardDirX; // World space forward X direction (normalised)
    int16 m_worldForwardDirY; // World space forward Y direction (normalised)
    int16 m_worldForwardDirZ; // World space forward Z direction (normalised)
    int16 m_worldRightDirX; // World space right X direction (normalised)
    int16 m_worldRightDirY; // World space right Y direction (normalised)
    int16 m_worldRightDirZ; // World space right Z direction (normalised)
    float m_gForceLateral; // Lateral G-Force component
    float m_gForceLongitudinal; // Longitudinal G-Force component
    float m_gForceVertical; // Vertical G-Force component
    float m_yaw; // Yaw angle in radians
    float m_pitch; // Pitch angle in radians
    float m_roll; // Roll angle in radians
    struct PacketMotionData
    PacketHeader m_header; // Header
    CarMotionData m_carMotionData[20]; // Data for all cars on track
    // Extra player car ONLY data
    float m_suspensionPosition[4]; // Note: All wheel arrays have the following order:
    float m_suspensionVelocity[4]; // RL, RR, FL, FR
    float m_suspensionAcceleration[4]; // RL, RR, FL, FR
    float m_wheelSpeed[4]; // Speed of each wheel
    float m_wheelSlip[4]; // Slip ratio for each wheel
    float m_localVelocityX; // Velocity in local space
    float m_localVelocityY; // Velocity in local space
    float m_localVelocityZ; // Velocity in local space
    float m_angularVelocityX; // Angular velocity x-component
    float m_angularVelocityY; // Angular velocity y-component
    float m_angularVelocityZ; // Angular velocity z-component
    float m_angularAccelerationX; // Angular velocity x-component
    float m_angularAccelerationY; // Angular velocity y-component
    float m_angularAccelerationZ; // Angular velocity z-component
    float m_frontWheelsAngle; // Current front wheels angle in radians
  10. alexdraco
    alexdraco Member
    278Coins
    Thank a lot
  11. BlazinH
    16,574Coins
    If the 2018 telemetry is the same as 2017 renaming the 2018 .exe to the 2017 .exe may be a temporary way to trigger the plugin until it gets updated. It's always worth a try.
  12. alexdraco
    alexdraco Member
    278Coins
    Ciao,
    Yes you are right.
    Worth a try.
    Thank you
  13. JonBakhol
    JonBakhol Active Member
    Netherlands harderwijk
    442Coins
    What I read about F1 2018 is that in this version the telemetry is send in multiple packages. While inF1 2017 all the telemetry is send in 1 package.
    So most likely it won't work. Give me a shout when it does, getting bored to sit still while driving.:p
  14. Wiseman1
    Wiseman1 New Member Gold Contributor
    Netherlands
    - 56Coins
    With the Steam version it doesn't work, because Steam will say something like it is unable to find the F1 2018.exe...
    In the meantime, I think we just have to be patient :(
  15. alexdraco
    alexdraco Member
    278Coins
  16. JonBakhol
    442Coins
    It has arrived thanks to @value1.
    Give it a shot and let him know if you like it.
  17. alexdraco
    alexdraco Member
    278Coins
    Ciao,
    thanks for the tip. I'll download it.
    First of all, I thank "value1" for the work done.
    I can give you feedback as soon as I can.
    Unfortunately I still can not make the SIM work in trouble with Sim Tools.
    noorbeast is helping me but I have not solved yet.
  18. JonBakhol
    442Coins
    Hi @alexdraco
    Yeh, I saw you had some problems with your sim.
    Have you tried SMC3 utilitiy? For me it was a great help to get my SIM up and running.
    https://www.xsimulator.net/communit...3dof-motor-driver-and-windows-utilities.4957/
    Download the Arduino code for SMC3 and upload it to your arduino.
    Then follow the steps on that page.
    Hopefully you will get it running soon.
    BestRegards
    Bakhol
  19. alexdraco
    alexdraco Member
    278Coins
    Hi JonBakhol,
    I tried to use SMC3 when I had everything on the workbench for the first tests.
    When I discovered faults on SMM cards.
    If you think that my problems come from electric motor settings, I will try again SMC3.
    Thank you for your suggestion.
  20. JonBakhol
    442Coins
    Hi @alexdraco,
    Be sure that you wire up both the MM boards correctly.
    There is also an description to wire up 2 MM boards on 1 Arduino. (just scroll a little, you will find it on the same page of SMC3)
    I tried it at first also with Racing mat's code. But the SMC3 code was good right away.
    Good luck
    Bakhol
