Wagnard
Elite Dangerous Horizons/Odyssey Plugin (XML edition) 4.2.1.1 pointer update
  1. Mechromancer
    Mechromancer Active Member Gold Contributor
    434Coins
    Man seriously, awesome of you to get on it so quickly.
    I would not be opposed to "buying you a beer" ;) for your hard work.
    Thanx!!
  2. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,156Coins
    All done, see my last post with updated XML.
    Please confirm if it work for both Ship & SRV so I can compile it officially into the plugin.
    Awaiting reviews ;)
    • Like Like x 5
  3. Mechromancer
    434Coins
    Unfortunately, I don't have an SRV yet.
    But everything is working perfectly for the ship, in my case.
    Thanx again.
  4. Benji85
    Benji85 Member Gold Contributor
    851Coins
    downloading the update now thanks for your work again Wagnard
  5. kev b
    kev b Active Member
    Swindon, UK
    929Coins
    Hi @Wagnard - reporting back
    Many thanks for the xml data
    Ship moves are working well. I used your initial xml for a fair bit of game-play yesterday. Just updated the xml to the latest with srv - but no srv game data (or motion) when I tried it in the ED srv demo (no srv at mo in main game so best I could do). Ship motion on all 6 axis is working fine tho.
  6. Wagnard
    Wagnardsoft
    5,156Coins
    Thanks @kev b , I just saw I did a (copy/paste) error with some SRV value.
    Here is the updated one.
    If you can test again in the SRV training and confirm I would appreciate
  7. kev b
    kev b Active Member
    Swindon, UK
    929Coins
    I'm about to check it out now
    UPDATE: Just rechecked it with latest xml (above) and confirm still no srv game data
  8. Wagnard
    Wagnardsoft
    5,156Coins
    Check again. according to the forum, no one downloaded it from my last post.
    Inside for SRV roll, there should be :
    <SRV_Roll
    Offsets="7"
    Offset_0="03B87DF0"
    Offset_1="30"
    Offset_2 ="268"
    Offset_3 ="4C0"
    Offset_4 ="558"
    Offset_5 ="70"
    Offset_6 ="400"
  9. kev b
    kev b Active Member
    Swindon, UK
    929Coins
    Hi @Wagnard
    I checked again. I definately had grabbed that last xml from above and confirm I'm using the same address and offsets for srv_roll you show above so defo using the latest xml data
  10. kev b
    kev b Active Member
    Swindon, UK
    929Coins
    Aside, you may want to hold-fire on putting (more) time to the srv moves for now. Reading the bad press on forums about some of the bugs in the latest ED update - FD may likely do a further patch (last time they did that in April tho the motion data was unaffected, other times tho, motion data mem locations change again) -
    I'm happy to keep testing if you do tho - I'm in cqc but got a separate screen up for web
  11. Wagnard
    Wagnardsoft
    5,156Coins
    It's not a problem, smaller patch are easier to get the new value.
    Also would you mind if I check something in "CheatEngine" on your side via teamviewer? just to help confirm some values.
    Edit: NVM , I was able to repro on my end,
  12. kev b
    kev b Active Member
    Swindon, UK
    929Coins
    Can do. I have just installed teamviewer. How do you want to proceed?.
    UPDATE: Ah - just read your last post - .
    It's getting nearly 'pub' time anyway here. I'm about tomorrow a lot of the day if you need more data
  13. Wagnard
    Wagnardsoft
    5,156Coins
    Thanks, Ill keep you informed.
    Edit: @kev b I think I know why it didn't work for you. I guess it is because you were not using the latest plugin that added GameVibe support. The new XML is base on that plugin.
    Anway will update with a compiled version now. I have tested on my side and all is ok.
  14. Wagnard
    Wagnardsoft
    5,156Coins
  15. kev b
    kev b Active Member
    Swindon, UK
    929Coins
    Ah - that's gotta be it. I've gotten used to just cut-pasting the successive xml data into the 'older' xml offsets file.
    I'll update the plugin, repatch, check xml etc in the morning. Thanks for the work you've put in.
  16. kev b
    kev b Active Member
    Swindon, UK
    929Coins
    All working after I updated the plugin - thanks again @Wagnard
  17. George Dobransky
    Hungary
    - 43Coins
    Hello There,
    It's great to see that you are still active with the plugin. In two weeks I'll come back
    from the summer season work from the seaside back to my home that means
    I'll get back to my spaceship finally....
    It was a long period without space....I'm so excited now...
    o7
    George
  18. Wagnard
    Wagnardsoft
    5,156Coins
    For information, the pointers survived today's patch (September update 1) ! :D
    • Like Like x 5
  19. polybasss
    polybasss Member Gold Contributor
    Burgos Spain
    155Coins
    yes, I tried it this afternoon, the SRV ones also work :thumbs
  20. Dani
    Dani New Member Gold Contributor
    105Coins
    Hi, I'm new to simtools and motion sim in general. I have tested the plugin and seen it works on my computer with my YAW VR motion sim.
    But I have a problem:
    I cannot find the pluigin folder nor the xml file to change values there. I had read simtools instrucctions and this forum entry and the older one and cannot find where its located.
    I have checked my simtools installation folder and there isnt a plugin folder.
    Hope you can help me thanks!
